water flow indicator
flowmeter8c51e
DateTime 06/08/2026 Show 214
How to pass Level 2 of Water Flow 2? Thank you? |heat flow meter
Effevtive Time:5/16/2026
Keywords:How to pass Level 2 of Water Flow 2? Thank you? |heat flow meter
『water flow indicator|heat flow meter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Level 2 operation process of Water Flow 2: Clear level tasks: This level requires collecting red and yellow liquids, using two horizontal pins to control the flow of the liquids, and finally filling the truck with the two liquids and transporting them away.. The initial state of the level is shown in the following figure: Open the horizontal pin below the red liquid: Click on the horizontal pin below the red liquid to make it flow down into the truck. The state after operation is shown in the following figure: Note: Ensure that the truck is located directly below the pin and there are no other obstacles blocking the flow of liquid. Open the horizontal pin on the bottom of the yellow liquid: After the red liquid has completely flowed into the truck, click on the horizontal pin below the yellow liquid to make it flow downwards into the same truck. The state after operation is shown in the following figure: Key point: Wait for the red liquid to stop flowing before operating the yellow pin to avoid liquid mixing or overflow. Complete loading and customs clearance: When both liquids are filled into the truck, the system will automatically trigger a transportation animation and pop up a customs clearance screen, as shown in the following figure: prompt: If the liquid is not completely filled into the truck, check the sequence of pin operations or whether the liquid flow is blocked. Summary: The core of this level is to operate the pins in sequence, releasing the red liquid first and then the yellow liquid, to ensure that both flow smoothly into the same truck. Attention should be paid to timing during operation to avoid liquid overflow or mixing failure.
2. English
translation expert in the short article. Thank you very much
The function of defense is located at the first under floor of this building. It is used both war and peace time for persons hiding room in Class VI and war preparedness saving room, for car and motorcycle parking during the peacetime and for protection unit and materials storeroom after closed during wartime. The area of the basement is to be calculated the same as the covered area of the first floor. The Fire-fighting gateway was airtight and gas defense passage. The protection system has equipped with the dried-toilet, the water tank and the sump. The design of the airtight door and interior finishing above the function of defense is strictly according to regulations. While waterproofing by concrete itself and using the abroad self-waterproof materials, the problem of waterproof and dampproof is solved. The project is designed according to the Class I fire control standard. The fire-incident auto-alarm system and the fire control room are in the same floor. The intelligent fire alarm and fire control system contains the manual alarm button, the detector, the flow indicator of the spraying system and so on, which are located warning device, and both the ganging control system and intelligent control system in the fire control centre. the High floor main building use concentrated closed bus or prefabricated branch cable with trunk distribution system, while other buildings use radial distribution system. All fire control device and other important power loadings are supplied by power change-over box of two independent power supply. Automatic fire alarm system, fire incident automatic arm system, fire control room, manual alarm button, fire detector,
