『ultrasonic water meter price|magnetic flow meter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. Request professional English translation between water meters. A water meter, also known as a water meter, is a device that measures the amount of water used. Commonly seen on the user end of tap water, its degree is used as the basis for calculating water bills. Water meters typically measure in cubic feet (ft ³) or cubic meters (m ³). So "water meter room" can be translated as: Water meter room or Room of Water metering. Water meter readings from right to left are 0.1 liters, 1 liter, 10 liters, 100 liters, 1 cubic meter (1000 liters), 10 cubic meters, 100 cubic meters, 1000 cubic meters. Types of displacement water meters, displacement water meters, velocity water meters, jet meters (single jet and multi jet), turbine meters, propeller meters, and MAG meters. Composite meters include electromagnetic meters, ultrasonic meters, and other types of flow meters? Flow meter is a professional automated measuring instrument, whose main function is to measure the flow rate of fluids, including liquids, gases, steam, mixed slurries, solid dust, etc. It is precisely the special role of flow meters that in the field of industrial automation, flow meters and sensors are called the eyes of automation systems. The measurement results are transmitted to the upper computer system, which integrates and analyzes the data, and then applies the preset solutions to the upstream and downstream control systems to achieve intelligent automatic control. Common flow meters include: measuring cleaning liquids such as electromagnetic flow meters, ultrasonic flow meters, vortex flow meters, mass flow meters, orifice flow meters, turbine flow meters, metal rotor flow meters, etc. Measuring gases such as vortex flow meters, V-cone flow meters
, orifice flow meters, balance flow meters, waist wheel flow meters (Roots), gas mass flow meters, etc. Measuring steam such as orifice flow meters, vortex flow meters, bend flow meters, etc. Measuring slurries such as electromagnetic flow meters. Users should choose the correct flow meter according to the requirements of the application scenario. Choosing the wrong flow meter will not only affect the project and production, but also cause unnecessary losses to the control system. If you are interested in measuring the flow rate of liquids, you can learn about TSD electromagnetic flow meters, which have high product accuracy and are suitable for various environments. 3. What are the performance characteristics of ultrasonic liquid level sensors?
Ultrasonic level gauges can adopt two-wire, three wire, or four wire technology. The two-wire system is: power supply and signal output are shared; The three wire system is: the power supply circuit and the signal output circuit are independent. When using DC 24V power supply, a 3-core cable can be used, and the negative end of the power supply and the negative end of the signal output share the same core wire; The four wire system is: when using AC 220V power supply, or when using DC 24V power supply and requiring complete isolation between the power supply circuit and the signal output circuit, a 4-core cable should be used. DC or AC power supply, with 4-20mADC and high/low switch output. The range of the split type ultrasonic level gauge is 0-50 meters, with multiple forms to choose from, suitable for various corrosive and chemical applications, high accuracy, remote signal output, and PLC system monitoring. The working principle of an ultrasonic liquid level m
