Gas specific flowmeter
Do you know the scope of use of orifice flow meters? |Which domestic vortex flowmeter is better? Why is it necessary to use a furnace specific V-cone flowmeter to measure furnace gas|
Keywords:Do you know the scope of use of orifice flow meters? |Which domestic vortex flowmeter is better? Why is it necessary to use a furnace specific V-cone flowmeter to measure furnace gas|
Company:water consumption meter for home
『Gas specific flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1.80 Gas shut-off valve size
PN16. The size of valve DN80 is based on the structural length standard of PN16. The Songchi Tan has a short series of 203mm and a long series of 280mm, while the flange size is based on PN16. Special industrial valve DN80 for natural gas valve, gas valve, and flow meter, with a nominal diameter of 319 * 200 * 352 (mm). Z45X-10Q stainless steel flange concealed stem elastic seat seal gate valve Z45X concealed stem soft wild tung seal gate valve, nominal diameter: 40-600.
2. What are the usage ranges of orifice flow meters? Do you know?
Application scope of orifice flowmeter
1. Industrial production process flow meter is one of the major types of instruments and devices in process automation. It is widely used in various fields of the national economy such as metallurgy, electricity, coal, chemical, petroleum, transportation, construction, textile, food, medicine, agriculture, environmental protection, and peoples daily life. It is an important tool for developing industrial and agricultural production, saving energy, improving product quality, enhancing economic efficiency and management level. It occupies an important position in the national economy.. In process automation instruments and devices, flow meters have two main functions: as detection instruments for process automation control systems and as total quantity meters for measuring material quantities. Secondly, energy metering is divided into primary energy (coal, crude oil, coalbed methane, petroleum gas, and natural gas), secondary energy (electricity, coke, artificial gas, refined oil, liquefied petroleum gas, steam), and energy carrying working fluids (compressed air, oxygen, nitrogen, hydro
gen, water). Energy metering is an important means of scientifically managing energy, achieving energy conservation and consumption reduction, and improving economic efficiency. Flow meters are an important component of energy metering instruments. Commonly used energy sources such as water, artificial gas, natural gas, steam, and oil all use an extremely large number of flow meters, which are indispensable tools for energy management and economic accounting. Thirdly, the discharge of smoke, waste liquid, sewage, and other pollutants from environmental protection projects seriously pollutes the atmosphere and water resources, posing a serious threat to the human living environment. The country has made sustainable development a national policy, and environmental protection will be the biggest issue of the 21st century. To control air and water pollution, it is necessary to strengthen management, and the basis of management is quantitative control of pollution levels. China is a country that relies mainly on coal as its energy source, with millions of chimneys continuously emitting smoke into the atmosphere. Smoke emission control is an important project to eradicate pollution. Each chimney must be equipped with smoke analysis instruments and flow meters to form a continuous emission monitoring system. The flow rate and volume of flue gas pose significant challenges, including large and irregular chimney sizes, variable gas composition, wide flow velocity ranges, dirt, dust, corrosion, high temperatures, and the absence of straight pipe sections. 4. There are five modes of transportation: railway and highway, aviation, water transportation, and pipeline transportation. Although pipeline transportation has long existed, it
