『Which is a good non full tube flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. Precautions for installation of non full tube flowmeter
The installation core of non full tube flowmeter lies in selecting a stable flow position and correctly installing and debugging it, which is the prerequisite for ensuring measurement accuracy. After understanding its working scenario, we naturally need to pay attention to the specific installation points. The selection of installation location and pipeline status is crucial for measurement. Prioritize selecting horizontal or slightly inclined downward pipeline sections, which can effectively avoid the generation of bubbles or unstable flow inside the pipeline. At the same time, sufficient straight pipe sections must be reserved upstream and downstream of the installation point. Generally, the length of the upstream straight pipe section is required to be no less than 10 times the diameter of the pipe and no less than 5 times the downstream to ensure that the fluid can pass through the flowmeter in a stable flow state. To avoid interference sources, the flowmeter should be kept away from equipment such as pumps and valves that can easily cause fluid pressure fluctuations and vortex generation. In addition, the installation location should also avoid strong electromagnetic field environments, such as near large motors or transformers, to prevent interference with signal transmission. When installing sensors, it is necessary to ensure that the sensors are tightly attached to the inner wall of the pipeline, with good sealing to prevent any leakage. The direction of the sensor must also be correct, and it must be installed according to the fluid flow direction indicated on the flowmeter housing. All electrical connections should strictly follow the product
2. What are the types of mass flow meters?
3. How can ultrasonic flow meters be used when the flow rate is not full of the pipe?? Knowing these three points is enough!
Three solutions for using ultrasonic flow meters when the flow rate is not full: In flow measurement, the full tube state is one of the basic conditions to ensure measurement accuracy, and ultrasonic flow meters are no exception.. However, in practical applications, in many working conditions, the pipeline liquid is not in a full state, but flow measurement must be carried out. In response to this situation, there are three effective solutions:
First, changing the diameter of the pipeline. Solution: If the pipeline where the measurement was originally intended is thicker and the liquid inside the pipeline is often in a non full state, it can be considered to replace the pipeline with a smaller diameter pipeline. By reducing the diameter of the pipeline, the pressure of the liquid inside the pipeline can be increased, making it easier to reach the full pipe state. Then, install an external clamp type ultr
