『Manufacturer of metal tube flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. Introduction of Tianjin Flow Meter Co., Ltd.
Tianjin Flow Meter Co., Ltd. (formerly known as Tianjin Automation Instrument 14th Factory and Tianjin Flow Meter Factory) is a subsidiary of Tianjin Tianyi Instrument Group, one of the four major instrument bases in China. It is a professional manufacturer designated by the Ministry of Machinery to produce flow meters, with a history of more than 40 years in the production of flow meters and a registered brand of "Upstream". The company has a factory area of 4000 square meters, a registered capital of 11 million, and 110 employees, of which more than 70% are technical personnel and engineers. The companys glass laughing rotor flowmeter, vortex flowmeter, turbine flowmeter, electromagnetic flowmeter, metal tube float flowmeter, level gauge, floating ball level gauge, throttling device and other flowmeter products are widely used in industries such as petroleum, power, chemical, metallurgical, pharmaceutical, and tap water, and exported to Southeast Asia and Central Asia. The magnetic flip level gauge is the first lifting product in China to introduce advanced German technology Upstream brand has become a well-known brand both domestically and internationally. The company can also customize various special specifications of flow meters and level gauges according to customer requirements. The company has liquid and gas calibration equipment for producing flow meters, with an accuracy of up to 0.2 level. It is a metrological calibration station commissioned by the Tianjin Metrology Bureau and can also provide calibration and verification services for various liquid and gas flow meters for the same industry or users. At the same time, it issues calibration certificat
2. Drainage pipe network flowmeter
3. Which flowmeter is good?
Hello, KNKE, an American imported flowmeter manufacturer, is pleased to answer your question. There are many manufacturers of flow meters, and this answer recommends the imported flow meters from the American brand KNKE. The reasons are as follows:
1. Multi parameter measurement, while measuring the radial flow, can simultaneously obtain the volume flow source, density, and viscosity value.
2、 Not sensitive to factors such as pressure, temperature, density, and dryness, as well as the distribution of flow velocity. KNKE imported flow meters from Konko are easy to install, with sensor tubes of various sizes being freely adjustable in their inlet and outlet directions for installation.
4、 Directly measuring the quality of the fluid and achieving true high-precision flow measurement.
5、 There are no suction points, no movable parts, and no electrode contamination issues in the pipeline, so the failure rate is low due to the small number of households. At the same time, it is easy to clean, maintain, and upkeep.
6、 Can handle a wide range of media, such as gases, liquids
