Intelligent Vortex Steam Flow Meter
rotameterb0012
DateTime 07/16/2026 Show 137
Do you know the advantages and disadvantages of steam vortex flowmeter and balance flowmeter? |What is a steam flowmeter | What is an intelligent vortex flowmeter|
Keywords:Do you know the advantages and disadvantages of steam vortex flowmeter and balance flowmeter? |What is a steam flowmeter | What is an intelligent vortex flowmeter|
『Intelligent Vortex Steam Flow Meter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Steam vortex flowmeter and balance flowmeter each have their own advantages and disadvantages, as follows: Advantages of steam vortex flowmeter: Strong measurement function applicability: It is a commonly used flowmeter in steam measurement, suitable for measuring the volume flow of steam. With auxiliary instruments such as pressure transmitters, temperature sensors, and intelligent flow integrators, it can accurately calculate the mass flow of steam.. Outstanding performance advantages: low pressure loss, which can reduce energy loss to fluid systems. Wide measuring range, suitable for measurement needs of different flow rates. High measurement accuracy, able to provide accurate data for flow measurement. Without moving parts, it reduces the probability of failure caused by component wear and tear, and has high reliability. Small maintenance volume, good long-term stability, reducing daily maintenance costs and workload. Strong anti-interference ability: almost unaffected by parameters such as fluid density, pressure, temperature, viscosity, etc., it can maintain measurement accuracy under different working conditions. Flexible application scenarios: Especially suitable for use in working conditions with unclear flow in the early design stage, and also suitable for trade measurement and settlement. Disadvantage: No obvious drawbacks have been mentioned yet. Advantages of balanced flowmeter: Clever structural design: As a new type of differential pressure measuring instrument, it can achieve high-precision and long-term stable measurement with relatively small permanent pressure loss in exchange for larger stabl
e differential pressure values under the requirements of shorter straight pipe sections. Excellent comprehensive performance: It has the advantages of easy installation, reliability, safety, high temperature resistance, and wide applicability of standard throttling devices. High precision, capable of providing accurate flow measurement data. The straight pipe section has low requirements, saving installation space and costs. Wide range ratio, able to adapt to measurements in different flow ranges. Low permanent pressure loss, reducing energy consumption. Overcoming habit defects: Overcoming the shortcomings of standard throttling devices such as debris retention, blockage, easy edge wear, and high maintenance costs. Clear applicable working conditions: Suitable for measuring stable flow, high temperature, high pressure and other working conditions, such as external network outlet summary table and branch summary table. Disadvantage: Not suitable for working conditions with large flow fluctuations, which may result in inability to measure low flow limits or insufficient measurement.
2. What is an intelligent vortex flowmeter?
Also known as Karman vortex street or Karman vortex, it is a physics theory proposed by Hungarian American aerodynamicist, Feng Karman, and also the doctoral supervisor of Qian Xuesen in China.. Vortex street refers to the phenomenon of unstable boundary layer separation that occurs in a fluid containing a blocking fluid under specific conditions. Two asymmetrically arranged vortices are generated on both sides downstream of the blocking fluid, with one vortex rotating clockwise and the other vortex rotating counterclockwise. The two rows of vortices are arranged in a staggered m
