『Lugb steam flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Which company should I look for for for laboratory gas flow meters?
2. Saturated steam flowmeter Selection of saturated steam flowmeter
Model and marking instructions: LUGB □□□□□□ Stress type vortex flow sensor - ② ③ ④ - ⑤ ⑥ Serial number Connection method: 1 Flange connection type 2 Flange card type tested medium: 1 Liquid 2 Gas (including steam) sensor nominal diameter: DN010-10 mm (non-standard) DN012-12.5 mm (non-standard) DN015-15 mm (non-standard) DN020-20 mm (non-standard) DN02-25 mm DN03-32 mm (non-standard) DN04–40 mmDN05–50 mmDN06–65 mmDN08–80 mmDN10–100 mmDN12–125 mmDN15–150 mmDN20–200 mmDN25–250 mmDN30–300 mmDN35–350 mmDN40–400 mmDN45–450 mmDN50–500 mm Unmarked pulse output standard flow range K pulse output extended flow range B explosion-proof M current output DC4-20mA local display 24V power supply condition various parameters XM local display 24V power supply three wire current output BM explosion-proof, current output DC4-20mA Determination and installation design of instrument caliber: 5 Instruments can be installed horizontally, vertically, or obliquely on pipelines. When measuring gases, instruments can be installed in vertical pipelines with no restrictions on gas flow direction. But if the pipeline contains a small amount of liquid, in order to prevent liquid from entering the instrument measuring tube, the airflow should flow from bottom to top. When measuring liquid, in order to ensure that the tube is filled with liquid carefully, when installing instruments in vertical or inclined pipelines, the direction of liquid flow should be from bottom to top. If the pipeline contains a small amount of gas, in order to prevent gas from entering the instrument measuring tube, the instrum
3. Technical parameters of LUGB vortex flowmeter
· Measurement medium: a. Zentong liquid: cold water, hot water, various oil products, liquefied petroleum gas, various chemical liquid oils b. Gas: compressed air, oxygen, natural gas, petroleum gas, and various chemical gases c. Saturated steam and superheated steam with a temperature below 350 ℃ · Measurement possible range: Reynolds number of 5000~7000000 · Normal working range: Reynolds number of 20000~7000000 · Accuracy: liquid ± 1%;
; Gas and steam ± 1.5% · Power supply voltage: 24VDC (intrinsically safe flow meters
