Wiegand flowmeter
What is the price of an electronic flowmeter? |Flow sensors measure flow inaccurately | Introduction to Wiegand sensors | Product composition of zero power magnetic sensors|
Keywords:What is the price of an electronic flowmeter? |Flow sensors measure flow inaccurately | Introduction to Wiegand sensors | Product composition of zero power magnetic sensors|
『Wiegand flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. Product composition of zero power magnetic sensor
Zero power magnetic sensor is a magnetic sensor developed using the Wiegand effect. It consists of two parts:
1. Sensitive alloy wire;
2、 The detection coil wrapped around the gold wire of Heshan Socks. When there is relative motion between the measured magnet and the sensor, an appropriate external magnetic field acts on the alloy wire, causing the magnetization of the inner core to jump and the detection coil to output induced voltage pulses. Therefore, this voltage pulse can be used to detect the movement of magnets and applied to instruments that indirectly measure various physical quantities, such as flow meters, three meter reed pumps (water meters, gas meters, heat meters), tachometers, angle detectors, passive pulse generators, contactless limit switches, and so on.
2. What is the price of an electronic flowmeter?
3. The flow sensor measures the flow rate inaccurately
My judgment:
1. Perhaps your flow meter has chosen a larger range, which may also result in inaccurate data due to the fact that your measurements are only 100 milliliters each time, which is not very large.;
2、 Attention should be paid to the straight pipe section before and after the flow meter, otherwise the measurement will not be accurate;
3、 Extend the time of turning on the electric Tong Xun machine, and then observe;
4、 Ensure that PLC measurement does not lose pulses;
4. What is the difference between a Wiegand sensor and a reed switch?
Wiegand Sensor In 1974, American physicist Wiegand discovered that after appropriate treatment, the metal phase of the alloy wire changes, and the coercivi
Wiegand flowmeter
ty of the outer shell is much greater than that of the inner core. By relying on this magnetic difference and a certain external magnetic field condition of the burnout skin, the magnetization direction of the inner core can be made the same or opposite to that of the outer shell, and this magnetization change can be repeated with a determined external magnetic field.. This phenomenon is called the "Wei Bai virtual root effect". Zero power magnetic sensor is a magnetic sensor developed using the Wiegand effect, which consists of two parts:
2、 A detection coil wound around the alloy wire. When there is relative motion between the measured magnet and the sensor, an appropriate external magnetic field acts on the alloy wire, causing the magnetization of the inner core to jump and the detection coil to output induced voltage pulses. Therefore, this voltage pulse can be used to detect the movement of magnets and applied to instruments that indirectly measure various physical quantities, such as flow meters, three meters (water meters, gas meters, heat meters), tachometers, angle detectors, passive pulse generators, contactless limit switches, and so on. The reed switch is a special type of magnetic sensitive differential switch. When the permanent magnet approaches the reed switch, or when the coil wound on the reed switch is energized to form a magnetic field that magnetizes the reed switch, the contacts of the reed switch will induce magnetic poles of opposite polarity. Due to the opposite polarity of the magnetic poles and mutual attraction, when the attractive magnetic force exceeds the resistance of the spring, the separated contacts will be attracted; When the magnetic for
