『LZ metal tube rotor flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
What is the approximate price of a rotor flowmeter?
2. Accuracy of LZB-25 gas float flowmeter
The accuracy of LZB-25 gas float flowmeter needs to be distinguished according to specific models, and the accuracy level of different categories varies greatly. Ordinary LZB-25 glass rotor flowmeter: The accuracy level of this conventional model is 1.5
2. LZB-25F corrosion-resistant glass rotor flowmeter: This model is designed for corrosive gases, with an accurac
3. LZ-25 metal tube float flowmeter: The accuracy of this model is divided into two levels, with a standard accuracy level of 1.5 and a special customized accuracy level of up to 1.0.
3. Metal rotor flowmeter, local pointer indication, mechanical display of instantaneous flow, no remote transmission. This flowmeter is ..
No battery is required, the energy that drives the pointer to deflect comes from the dynamic pressure energy of the medium flow.
