『DN80 sewage flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
What is the approximate price of a water flow meter?
2. The instantaneous display of negative values on the flowmeter
There are four core reasons for the instantaneous display of negative values on the flowmeter, and the corresponding solutions need to be checked one by one.. When the actual flow direction of the fluid in the pipeline is opposite to the preset direction of the flowmeter, negative values will appear. Similar cases of hot water backflow in branch pipes due to changes in main pipe pressure in heating systems are not uncommon in practical operations. • Cause investigation: Check whether there is backflow caused by valve failure or pressure difference formed by system design defects in the pipeline. • Solution direction: Priority should be given to repairing faulty valves, and check valves can be installed in complex systems. If necessary, the pipeline layout needs to be re evaluated.
2. Signal transmission is affected by electromagnetic interference generated by high-power equipment (such as motors and transformers), which can easily lead to abnormal signal transmission. I once encountered a chemical plant where the flow meter frequently jumped negative due to a dense group of motors. After replacing the shielded cable, the problem was easily solved. Interference identification: Observe whether negative values occur synchronously with device start stop. Anti interference measures: Double layer shielded cables and standardized grounding are used, and in extreme cases, they can be upgraded to fiber optic transmission systems. 3. Equipment failure, sensor aging, or circuit board damage can directly cause measurement abnormalities. A certain sewage treatment plant experienced elect
4. Parameter setting deviation: The range does not match the working conditions, which is a common human error. I have dealt with a case where a DN50 pipeline was mistakenly set to DN80 range parameters, and the measurement immediately returned to normal after resetting the parameters. Key points of verification: whether basic parameters such as flow rate range, pipeline diameter, and medium characteristics are accurately entered. Calibration technique: Perform zero calibration under static conditions and verify range accuracy in sections under dynamic conditions. The fluctuation test of pipeline pressure can be used as a comprehensive detection method to synchronously monitor the correlation between pressure changes and readings at the front and rear ends of the flowmeter, which can effectively distinguish between equipment failures and system operating conditions abnormalities. For intermittent negative values, it is recommended to add trend recording function to assist in problem localization.
3. Installation introduction of ultrasonic flowmeter
Time difference ultrasonic flowmeter is a competitive flow measurement method in the world today, with a measurement line accuracy of over 1.0%.
. Due to the diversity of the environment around industrial sites, especially pipelines, how to install and debug ultrasonic flow meter
