『Reasonable flow meter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. What standards are required for installing and using a flow meter to measure flow?
Installing and using a flow meter to measure flow usually requires meeting the four core standards of accuracy, installation conditions, fluid characteristics, and safety.
1. Accuracy Standards (1) Accuracy Level Adaptation Scenario 1 The accuracy requirements for trade settlement scenarios are high, generally ranging from ± 0.2% to ± 0.5%; The accuracy requirement for industrial process control scenarios is usually ± 1% - ± 5%. 2. Flow meters that match the corresponding accuracy level should be selected, and regular calibration should be carried out during use to ensure measurement accuracy.
II. Installation Condition Standards (1) Requirements for Straight Pipe Section 1 There are differences in the requirements for straight pipe sections of different types of flow meters. For example, for orifice flow meters, a straight pipe section of 10-50 times the pipe diameter length is required upstream, and a straight pipe section of 3-10 times the pipe diameter length is required downstream to ensure stable fluid flow. (2) Installation environment and location requirements 1 The flowmeter should be installed in a location that is convenient for daily maintenance and operation, avoiding harsh installation environments such as vibration, strong electromagnetic field interference, high temperature, and high humidity.
III. Fluid Characteristics Standards (1) Fluid Type Adaptation 1 Corresponding flow meters should be selected based on the type of fluid being measured: electromagnetic flow meters, turbine flow meters, etc. can be used to measure liquids; Gas can be measured using vortex flowmeters, gas turbine flowm
IV. Safety Standards (1) Explosion proof Safety Requirements 1 For flammable and explosive fluids, flow meters with explosion-proof functions should be selected and installed and used in accordance with relevant explosion-proof standards. (2) Electrical safety requirements 1 The electrical part of the flowmeter must comply with electrical safety standards to prevent safety accidents such as leakage.
2. Reasonable and correct installation position of steam flowmeter
The reasonable and correct installation position of steam flowmeter should meet the following conditions: avoid pipelines with strong vibration: The installation position of steam flowmeter should try to avoid selecting pipelines with strong vibration.
. If it cannot be avoided, vibration reduction measures must be taken, such as installing anti branch vibration short joints, to ensure that the measurement accuracy and service life of the flowmeter are not affected. Flexible installation direction: Steam flow meters can be installed horizontally, vertically, or diagonally, depending on the installation conditions and actual needs on site. However, it should
