『Automotive fuel flow meter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. Normal range of fuel flow meter pressure
The normal range of fuel flow meter pressure needs to be discussed in different scenarios: there is a significant difference between edible oil and automotive fuel, and it needs to be adjusted according to the instrument diameter or operating conditions. 1. In the edible oil scenario, the pressure range of the edible oil flowmeter varies depending on the diameter of the instrument. In actual use, it is important to pay attention to the flange connection method and pressure resistance level: • DN 4/DN 6/DN 10 diameter: conventional withstand pressure of 6.3MPa • DN 15-DN 40 diameter: 6.3MPa (threaded connection), 2.5MPa (flange connection) • DN 50-DN 100 diameter: 2.5MPa • DN 125-DN 200 diameter
1.6MPa. The specially designed pressure resistance level supports adjustment to 4.0/6.3/12/16/25MPa, usually requiring customized explanation with the manufacturer in advance
2. The pressure parameters of the automotive fuel system. The gasoline pressure value dynamically changes with the engine state, and the following are typical working condition reference values: • Ignition not started (electric) Pump operation: Oil pressure is about 0.3MPa • When clamping the return oil pipe: The maximum oil supply pressure of the oil pump reaches 0.5-0.75MPa (2-3) Multiple working pressure) • Idle operation: static pressure maintained at 0.25MPa, increased to 0.3MPa after removing the vacuum tube • Rapid acceleration state: oil pressure rapidly increased from 0.25MPa at idle to 0.3MPa. After stopping oil supply for 5 minutes, the system should maintain a pressure of ≥ 340kPa. The specific pressure range of the equipment may vary due to factors such as equipment model and lubr
