『Magmeter Flow Meter Selection and Installation Guide』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Quick Answer: A magmeter works only with conductive fluids, needs a full pipe and straight run, and must match liner and electrode material to your fluid. Silver Instruments delivers flowmeters sized to your exact pipe and process data. Send us your conductivity, pressure, temperature and pipe DN for a concrete part number and price.
Start With the Fluid Properties
Most engineers know the conductivity rule but ignore temperature and chemical attack. A magmeter demands a fluid conductivity above 5 µS/cm. For raw water or treated effluent this is rarely a problem. Demineralised water, boiler feedwater and some solvents fall below 3 µS/cm and need special capacitance electrodes. At Silver Instruments we often test a sample if a customer in Vietnam or Thailand sends us a small bottle.
Temperature kills the liner before the electrodes. Standard hard rubber liners handle 80 °C. PTFE liners go to 150 °C and PFA reaches 180 °C. A paint factory in Malaysia learned this the hard way. They ran a solvent at 140 °C through a rubber-lined meter and the liner swelled in three weeks. After we replaced it with a PFA liner and Hastelloy C electrodes the meter ran for three years without drift.
Pressure rating follows the flange standard. For PN16 we default to carbon steel flanges with a painted finish. For seawater we pick PN16 or ANSI 150 with 316L stainless flanges. Silver Instruments offers a lineup up to PN40 for high-pressure ammonia applications.
Choose the Right Liner and Electrodes
Liner and electrode selection is not a side note. It determines whether your meter survives the first CIP cycle or chemical batch. Hard rubber works for cold water and wastewater. PTFE is the universal choice for chemicals, acids and caustics. PFA offers the same chemical resistance with better temperature endurance and smoother surface, which helps pigging applications. For abrasive mining slurries we use soft rubber or ceramic. One iron ore plant in Western Australia runs ceramic liners with tungsten carbide electrodes and the meters last 18 months where the previous units lasted 4.
Electrode material follows the liner logic. 316L stainless works for water and mild chemicals. Hastelloy C suits acids and brines. Titanium is our standard recommendation for seawater and desalination brine because it resists pitting. Tantalum handles nitric acid. Platinum fits concentrated caustic and some pharmaceutical processes. When a customer in Chile sent us the water analysis from their lithium brine plant, we specced titanium electrodes with a PTFE liner. That meter has recorded zero drift after 14 months.
Size the Meter for Your Pipe, Not Just the Flow Rate
Many specifiers just match the meter DN to the pipe DN and hope for the best. This works if the flow velocity stays between 1 and 5 m/s. If the actual velocity falls below 0.3 m/s, accuracy drops. If it exceeds 10 m/s, the liner may abrade. We have seen a desalination plant in Oman that put a DN300 magmeter on a DN300 brine line where the daily flow gave only 0.15 m/s. Noise took over the signal. We swapped it for a DN200 meter with a concentric reducer and the reading became stable. The pressure drop stayed under 0.15 bar, well within the pump budget.
Use this rule: minimum flow velocity 0.5 m/s for reliable measurement, optimum 2 to 3 m/s. For viscous fluids below 30 cP the magmeter behaves like water. For higher viscosity above 100 cP you may need a positive displacement meter. A chemical trader in Indonesia tried to measure 200 cP resin with a magmeter an
Install It Where the Pipe Runs Full
Half-full pipe equals zero signal. The magmeter needs electrodes covered with liquid at all times. The best location is a low point in the piping where the pipe always stays flooded. Avoid the top of a loop, the discharge of a pump without a back-pressure valve and any free-fall discharge. If you must install in a vertical pipe, direct the flow upward, not downward. This keeps air bubbles from clinging to the electrodes.
A wastewater treatment plant in the Philippines had a problem. They installed the meter on a horizontal pipe but after a short elbow that dropped 1.5 metres before discharging to an open channel. The meter lost signal when the pump stopped because the pipe drained. We moved the meter to the pump discharge line before the rise, and the readings became consistent. They also gained a 0.3 bar back pressure, which helped de-aerate the fluid.
Meet Straight Run and Grounding Needs
Upstream we want 5 pipe diameters of straight pipe. Downstream 2 diameters is enough. If you put the meter right after a butterfly valve or an elbow, the distorted profile will cause a bias of 1 to 3 %. In practice many skids cannot achieve 5D. We then use a flow conditioner or accept a slight offset that we compensate during calibration. We document this for every meter if you tell us your piping layout with the order.
Grounding is critical for magmeters because the voltage signal is microvolt level. On metal pipe with a conductive gasket you may not need extra rings. On plastic or lined pipe, grounding rings or grounding electrodes are mandatory. We ship every meter with built-in grounding electrodes or include stainless rings when needed. For ATEX Zone 1 installations we provide intrinsically safe circuits with a 4-20 mA HART output. You can also add Modbus RTU or pulse output for batching. An oil terminal in Nigeria uses our explosion-proof magmeter for diesel loading and they have never lost a batch count.
What is the minimum conductivity for a magmeter?
Standard magmeters need at least 5 µS/cm. Our Silver Instruments models work stable from 3 µS/cm with a special electrode amplifier. For ultra-pure water below 1 µS/cm we recommend an ultrasonic or Coriolis meter.
Can I install a magmeter in a vertical pipe?
Yes, with flow moving upward. Avoid downward flow because air bubbles stick to the electrodes. Ensure the pipe stays full during zero flow. A check valve below the meter helps maintain back pressure.
What is the typical turndown ratio?
We specify 100:1 as standard. In practice, below 0.3 m/s the accuracy drifts. So you get a functional turndown around 30:1 if you sized the meter correctly for the normal flow range.
How do I choose between integral and remote transmitter?
Pick the integral version for ambient temperatures below 60 °C and when vibration is low. Choose the remote mount if the meter sits in a pit, gets direct sun, or runs hot fluid above 120 °C. We supply 10-metre signal cable as standard and can extend up to 100 metres with a junction box.
What information do you need for a quotation?
Send us the fluid name, conductivity in µS/cm, operating pressure in bar, temperature in °C, pipe outer diameter and wall thickness or nominal DN, flow range minimum and maximum in m³/h or litres per minute, and the signal output you need: 4-20 mA HART, pulse, Modbus or Profibus. We reply with a part number, price and lead time within one working day.
