Positive Displacement Flow Meter Ml/Min Repeatability Rules
Effevtive Time:7/27/2026
Keywords:Positive Displacement Flow Meter Ml/Min Repeatability Rules
『Positive Displacement Flow Meter Ml/Min Repeatability Rules』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Positive Displacement Flow Meter ml/min Repeatability Rules
Positive displacement flow meters deliver repeatability figures that engineers can trust for low flow batching and dosing jobs. For ml/min ranges, a quality oval gear meter typically holds repeatability within ±0.1% of reading or ±0.05 ml/min, whichever is greater. Silver Instruments ships every PD meter with a factory calibration sheet that confirms repeatability under ISO 17025, so you get hard data before the meter reaches your site.
What Repeatability Means for a ml/min PD Meter
Repeatability describes how close consecutive measurements remain when you measure the same flow under identical conditions. It is not the same as accuracy. A meter can repeat 1.5 ml/min every time but still show an offset from the true value. In dosing and injection applications, repeatability is often more valuable than absolute accuracy. Positive displacement meters, like oval gear or gear flow meters, trap liquid in fixed volume chambers. Each pocket volume is physically defined, so the mechanical cycle repeats within tight limits. At 500 ml/min, you can get readings that vary less than 0.5 ml/min between pulses. We have verified this on diesel, water, and solvents in our test loop.
Typical Repeatability Numbers from Silver Instruments PD Meters
Our oval gear PD meters cover flow spans from 0.5 ml/min up to 3,000 ml/min. The OGM-L micro oval gear series, with a DN4 or DN6 connection, achieves repeatability of ±0.1% of reading or ±0.03 ml/min. For heavier oils up to 1,000 cP, we often see lab results around ±0.05% because high viscosity prevents internal slippage. Every meter outputs a frequency signal; you can also get 4-20 mA HART or a local display. The turndown ratio can reach 100:1 without losing repeatability, a figure that ultrasonic or thermal mass meters struggle to match below 50 ml/min.
Last month, a desalination plant in Oman ordered OGM-L meters for antiscalant dosing at 12 ml/min. Their lab test confirmed repeatability within ±0.04 ml/min across three shifts. That gives the plant operator confidence in pump performance.
Practical Factors That Shift Repeatability
Even the best PD meter will drift if you ignore a few basics. Fluid cleanliness sits at the top. A particle of 50 microns can catch between oval gears and cause a temporary spike. Always install a mesh filter upstream, 75 micron or finer for clean solvents, 150 micron for fuel oils. Viscosity changes matter. A PD meter relies on a tight clearance. If temperature swings reduce oil viscosity from 500 cP to 50 cP, internal leakage goes up and repeatability widens, sometimes from ±0.1% to ±0.5%. So you either control temperature or select a meter with harder bearing materials and tighter
tolerances. Back pressure also helps. Maintaining at least 0.5 bar at the outlet keeps chambers full and avoids air pockets. In our service cases, a chemical batching plant in Thailand added a simple back pressure valve and brought repeatability back from ±2% to ±0.2%.
Application Scenarios Where ml/min Repeatability Rules the Process
Several industries treat repeatability as the pass-fail spec. Fuel consumption measurement on diesel engines is one. A test bench in the Philippines needed to log real-time fuel rate between 20 and 200 ml/min. The repeatability requirement was ±0.1 ml/min because carbon balance calculations demand tight data. We supplied two OGM-L-DN4 meters with Pt100 sensors. The bench now runs 8-hour cycles and prints repeatability reports for engine certification. Another case: a perfume compounder in France asks for stainless steel oval gear meters to dose aroma chemicals at 5 ml per shot. Here, repeatability of ±0.02 ml per shot matters more than absolute accuracy, because the recipe calls for consistent sensory profile. We can match that with a small chamber meter and dry run protection.
Send us your minimum and maximum flow rate in ml/min, liquid viscosity (cP), temperature, and pipe size. We will pick a PD meter with a repeatability target and share a sample calibration sheet.
FAQ on PD Meter Repeatability ml/min
What is the smallest repeatable flow a positive displacement meter can measure? We regularly test down to 0.5 ml/min. With a micro oval gear meter, you can get repeatability within ±0.03 ml/min for water-like liquids. For very low flows, you need a meter with hard jewel bearings and small chamber volume.
How often should you calibrate a PD meter for dosing jobs? We recommend a yearly calibration check for most water and chemical dosing applications. If you meter abrasive fluids or run 24/7 at high pressure, consider 6-month intervals. You can send the meter to our calibration lab or use a master meter on site.
Does high viscosity help or hurt repeatability? High viscosity usually helps. Thick liquids reduce slip between gears, so repeatability improves. However, very high viscosity above 2,000 cP may require larger clearances to avoid high pressure drop. We balance the design for your specific fluid.
Do you supply repeatability test reports with the meter? Yes. Every Silver Instruments PD meter comes with a 6-point calibration certificate that includes repeatability data at multiple flow points. The certificate references our ISO 17025 accredited lab.
What connection type is best for a 10 ml/min range? For low flows, compression fittings on DN4 or DN6 tube stub work best. Threaded NPT 1/8 or BSP 1/8 are also common. Avoid oversized connections that create dead volume and trap air.
