Brooks Flow Meter 3750: Sourcing Variable Area Process Loop Sizing Manuals
Effevtive Time:8/18/2026
Keywords:Brooks Flow Meter 3750: Sourcing Variable Area Process Loop Sizing Manuals
『Brooks Flow Meter 3750: Sourcing Variable Area Process Loop Sizing Manuals』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Quick Answer: Brooks Flow Meter 3750 manuals give sizing and loop wiring data for metal tube variable area flow meters in liquid, gas, and steam service. Engineers can use the same process data to source a compatible Silver Instruments metal tube VA meter with 4-20 mA HART output. Send your pressure (bar), temperature (°C), pipe size (DN), and flow range for a quote.
Why Engineers Search for the Brooks 3750 Manual
We see requests from Vietnam, Indonesia, Saudi Arabia, and Nigeria every month. A maintenance engineer needs the loop wiring diagram or the flow correction table before a shutdown. The Brooks 3750 variable area flow meter manual is not just a product catalog. It contains float sizing data, density correction, viscosity limits, and 4-20 mA HART connection drawings. In practice, most engineers skip the theory and go straight to the table for water or air.
Here is the thing. Process conditions on a site rarely match the standard table. A clean water calibration will not hold for a 200 cP polymer solution at 60 °C. That is where the size calculation in the manual becomes useful. If you do not have the manual, the supplier should be able to recalculate the range from your flow rate and density.
Sizing a Variable Area Meter for a Process Loop
A metal tube variable area meter is not a simple pipe spool. You need the fluid name, flow range, operating pressure, temperature, and pipe size. For example, a wastewater plant in Chile may need a DN80 meter for 10 to 100 m3/h of filtered effluent at 2 bar and 25 °C. The Brooks 3750 sizing tables will list the float material and the scale length for that range.
But most engineers skip this part. Then the float position does not match the transmitter reading. The cause is usually a density or viscosity correction that was ignored. For gas service, the pressure and temperature at the meter inlet change the actual flow from the standard flow. Check the manual for the correction formula. Or send the gas composition and inlet pressure to us.
4-20 mA HART Loop Wiring and Field Checks
The Brooks 3750 can be ordered with a 4-20 mA HART transmitter. Field wiring is usually two wire with a 24 V DC supply. The loop load must stay within the transmitter limit. For ATEX Zone 1 areas, confirm the Ex ia or Ex d model and use shielded twisted pair cable. The manual has a wiring diagram and terminal numbers.
We have seen this on customer sites many times. The loop wiring is correct. The transmitter range does not match the mechanical scale. The 4 mA point may be set at 0 L/h while the local scale starts at 50 L/h. This creates a 12 percent offset. Check both values before you close the junction box.
Sourcing the Brooks 3750 Manual and a Compatible Meter
You can download the origi
nal manual from the Brooks Instrument website. If you need a replacement meter, Silver Instruments supplies metal tube variable area flow meters in DN15 to DN100. Options include 4-20 mA HART, local pointer, PTFE liner, flange or thread connections, and Ex approvals for hazardous areas.
A paint manufacturer in Southeast Asia replaced a broken glass tube rotameter on a solvent line. The fluid was ethyl acetate at 25 °C and 1.5 bar. The flow range was 20 to 200 L/h. We supplied a DN25 metal tube VA meter with 4-20 mA HART. The plant used the Brooks 3750 manual for wiring reference and matched our terminal block one to one. The temperature sensor was a PT100 in a separate thermowell.
Another customer in Oman asked for a seawater flow meter for a desalination plant feed line. The line was DN50, pressure 6 bar, conductivity 2500 µS/cm, and flow range 5 to 50 m3/h. A metal tube VA meter with PTFE liner and 4-20 mA HART worked for the application. Many water and wastewater plants across the Middle East run the same loop configuration.
Silver Instruments Cross Reference Notes
Do not expect a part number to part number match with the Brooks 3750. The process connection, flow range, and output signal are the three items that matter. Most loops in oil and gas, water, chemical, food and beverage, and marine use a 4-20 mA HART signal. The manual gives you the loop data. We give you the meter and the sizing check.
For a quote, send us your pressure (bar), temperature (°C), pipe size (DN), and flow range. Tel: +86-135-1213-1526. WhatsApp: 86-135-12131526. WeChat: +86 13512131526.
Can I use the Brooks 3750 manual to size a different brand VA flow meter?
Yes for basic liquid and gas sizing. The formulas are similar across metal tube variable area meters. Confirm the float shape and scaling factor with the new supplier.
Does Silver Instruments stock a direct replacement for the Brooks 3750?
We supply a metal tube VA flow meter in DN15 to DN100 with matching 4-20 mA HART and local indicator. It is not a Brooks part number, but the process connections and loop wiring are often aligned. Send your tag number and process data.
What flow ranges are typical for the Brooks 3750?
Liquid ranges start around 0.1 L/h for small meters and go up to roughly 100 m3/h on larger sizes. Gas ranges depend on pressure and temperature. Check the manual for actual values.
What loop information do I need before wiring the 4-20 mA HART output?
Confirm the 24 V DC supply, loop resistance, ATEX zone, and whether the transmitter is Ex ia or Ex d. Use shielded twisted pair cable. The manual shows the terminal numbers.
How do I get a quote from Silver Instruments?
Send us your pressure (bar), temperature (°C), pipe size (DN), and flow range. Tel: +86-135-1213-1526. WhatsApp: 86-135-12131526. WeChat: +86 13512131526.
