Hedland Inline Flow Meter Alignments: Horizontal and Vertical Mounting Tips for Piston Sensors
Keywords:Hedland Inline Flow Meter Alignments: Horizontal and Vertical Mounting Tips for Piston Sensors
Company:flow measurement principle
『Hedland Inline Flow Meter Alignments: Horizontal and Vertical Mounting Tips for Piston Sensors』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Quick Answer: Horizontal mounting gives the most stable readings for Hedland style piston sensors. Vertical mounting works only with upward flow. Align the meter bore with the pipe centreline, support the pipe on both sides, and keep the dial face visible.
Why Alignment Matters for Piston Sensors
Hedland inline flow meter alignments decide whether the piston sensor reads true or drifts over time. The piston inside is spring loaded and moves through a tapered sleeve. If the meter body is slightly twisted or under pipe stress, the piston does not travel straight. The result is repeatability error and early wear.
Many installers treat these meters like a simple spool piece. In practice, alignment is the difference between a meter that repeats within 2 percent and one that gets blamed for bad batch data.
Horizontal Mounting Tips for Hedland Inline Flow Meters
Mount the meter in a horizontal pipe run whenever possible. Keep the dial face upward or within 45 degrees of vertical. This position keeps the piston axis horizontal and removes most gravity effects from the stroke.
Do not hang the meter body from the piping without supports. Use pipe stands or brackets on both sides. A meter installed close to a pump discharge without support can see side load. That side load pushes the piston against the sleeve and creates repeatability errors.
Keep the meter bore aligned with the pipe. For DN15 to DN50 meters, use the same nominal size connections and avoid sudden step changes at the threads. If you must reduce line size, put the reducer at least 10 DN upstream.
For oil service with viscosity below 100 cP, horizontal mounting is the best default. A customer in Vietnam used a Hedland H700 series style meter on a hydraulic test bench. The meter was horizontal, the oil was ISO VG 46 at 40 °C, and the reading repeated within 2 percent across a 5 to 40 L/min range.
Vertical mounting is acceptable if the flow direction is upward. The piston rises against the spring. At zero flow, gravity helps the piston settle to the bottom stop. This gives a stable zero point.
Do not install a Hedland style piston meter with downward flow. Gravity adds force to the piston and the dial can float above zero even with the pump off. We have seen this on customer sites many times. One unit read 6 L/min at zero flow. After the meter was rotated so flow moved upward, the zero returned and the reading settled.
For vertical upward flow with high viscosity fluid above 100 cP, install the meter after the pump discharge. Do not install it on the suction side. Suction side pressure swings can make the piston flutter.
Pipe Alignment and Support Before You Mount
Before you tighten any fitting, check the alignment of the pipe ends. If the pipe flanges or threads are forced to meet the meter, the body can distort. That distortion changes the piston clearance.
Use the flow arrow on the meter body and point it in the true flow direction. For horizontal runs, this may be left to right or right to left. The dial position matters more than the direction of the run.
For a clean signal, allow 10 DN
of straight pipe upstream and 5 DN downstream. Piston meters may tolerate less than other inline meters, but an elbow directly at the inlet creates swirl. Swirl pushes the piston off centre and gives unstable readings.
Common Errors We See on Site
One common error is using thread seal tape across the end of a threaded connection. The tape enters the flow path and catches on the piston. Use sealant on the male threads only and keep the first two thread tips clean.
Another error is using the meter body as a step or a wrench point during installation. That can dent the body and bind the piston. Most engineers skip this part until a replacement is needed.
Dirty fluid is also a frequent cause of piston drag. Add a strainer upstream if the fluid carries particles. For dirty water or slurry, a piston sensor is not the right tool. An electromagnetic flow meter for dirty water is a better fit.
Hedland Style Replacement Flow Meters from Silver Instruments
Silver Automation Instruments is a flow meter manufacturer and supplier for industrial users and distributors in Southeast Asia, Oceania, Latin America, Africa, and the Middle East. We supply inline flow meters for oil, water, and chemical lines in DN15 to DN50 sizes. We can match Hedland H700 series style piston meters with stainless steel or aluminium bodies. For viscous oil above 100 cP, we often supply an oval gear flow meter instead because it handles cold startup better.
If you need a transmitter output, we can supply 4 to 20 mA HART with a local display. For temperature-compensated oil measurement, we can add a PT100 probe. For oil and gas skids in ATEX Zone 1 areas, include the zone classification and gas group in your request.
Send us your pressure in bar, temperature in Celsius, pipe size in DN, flow range in L/min or kg/h, and the Hedland part number if you have it. We will confirm the replacement model and a quote. Tel: +86-25-68650347. Whatsapp: +86-25-52155837. WeChat: +86 15365082610.
FAQ: Hedland Inline Flow Meter Mounting
Can a Hedland inline flow meter be mounted vertically?
Yes, but only with upward flow. Downward flow causes zero drift and readings that are higher than actual flow.
Does horizontal mounting require a specific flow direction?
Flow direction must follow the arrow on the body. The dial face should point upward or within 45 degrees of vertical. The meter can run left to right or right to left.
How much straight pipe does a piston sensor need?
Use 10 DN upstream and 5 DN downstream. This prevents swirl from elbows or reducers and keeps the piston centred.
Can a piston type inline flow meter handle dirty water?
Not well. Small clearances can clog. Use a strainer upstream or switch to an electromagnetic flow meter for dirty water and slurry. For water and wastewater with conductivity above 5 µS/cm, an electromagnetic flow meter is a stronger option.
What information is needed for a Hedland replacement quote?
Send flow range, viscosity, pipe size, connection type, pressure, temperature, and the Hedland part number if available.
For a firm quote, contact Silver Automation Instruments directly. Tel: +86-25-68650347. Whatsapp: +86-25-52155837. WeChat: +86 15365082610.
