How to Calculate K Factor for Flow Meter: Divide the total number of sensor pulses generated during a test run by the exact volume of liquid collected.
flowmeter01956
DateTime 09/13/2026 Show 16
Keywords:How to Calculate K Factor for Flow Meter: Divide the total number of sensor pulses generated during a test run by the exact volume of liquid collected.
Company:v notch flow meter
『How to Calculate K Factor for Flow Meter: Divide the total number of sensor pulses generated during a test run by the exact volume of liquid collected.』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Quick Answer: Divide total sensor pulses by the exact volume of liquid collected during a test run. The result is the K factor in pulses per litre or pulses per gallon. Use a calibrated prover tank or a master meter to keep volume error below 0.2 percent.
Here is the thing. K factor is not a fixed universal constant. It shifts with field conditions. That is why the simple pulse divided by volume test still matters for industrial flow measurement.
Field K factor checks are not just a lab exercise. In practice we see customers verify K factor after installation because viscosity, flow profile, air pockets, and pipe vibration can shift the number. A paint manufacturer in Vietnam recently checked an oval gear meter on a 25 mm solvent line and found the K factor shifted 1.8 percent after a strainer clogged. That shift changed batch totals enough to fail a quality audit.
K Factor Formula for Pulse Output Flow Meters
The formula is simple. K factor equals total pulses divided by exact volume collected. If a pulse output flow meter generates 48,250 pulses during a run and the prover tank collects 500.0 litres, the K factor is 96.5 pulses per litre.
Do not use the volume displayed on the flow meter during the same test. That display already uses the existing K factor. You need the exact volume from a calibrated tank, a weigh scale, or a master meter with traceable accuracy.
Common K factor units include pulses per litre, pulses per gallon, and pulses per cubic metre. For water and wastewater lines in the Philippines and Indonesia, we normally quote K factor in pulses per litre. For diesel and fuel oil customers in Australia and the Middle East, pulses per gallon is common.
Step by Step Field Procedure for K Factor Verification
Install the flow meter in the line and purge all air. Run the process fluid at the normal operating flow rate for at least 30 seconds before starting the test. Divert flow into a calibrated tank. At the same time, start a pulse counter. The counter input should accept a frequency at least twice the maximum pulse frequency of the meter.
Record the exact volume from the tank sight glass or from a weigh scale. Stop the counter at the same moment you stop the flow. Divide the total pulse count by the exact volume. Repeat the test at minimum flow, normal flow, and maximum flow.
Most engineers skip this part. They test only at the normal flow rate. But a K factor that is linear at high flow can be 2 percent off at low flow on turbine meters. If the three K factor values are within plus or minus 0.5 percent of the average, use the average. If not, inspect for cavitation, pulsation, undersized pipe, or a damaged rotor.
Worked Example for Diesel in a 25 mm Line
A biodiesel blending site in Malaysia tested a Silver Instruments oval gear flow meter on a 25 mm diesel line. The fluid was diesel with viscosity 4.5 cP at 35 degrees Celsius. The prover tank collected 500.0 litres. The counter logged 48,250 pulses. K factor equals 48,250 divided by 500.0. That gives 96.5 pulses per litre.
The same meter was later tested at 200.0 litres. The counter logged 19,310 pulses. K factor came out to 96.55 pulses per litre. The difference was 0.05 percent. That result confirmed the mechanical meter repeatability was acceptable for batch loading.
K Factor Settings in the Flow Totalizer or PLC
After you calculate the K factor, enter it into the flow totalizer, the PLC analogue input card, or the batch controller. For Silver Instruments pulse output flow meters, the K factor is normally printed on the calibra
tion certificate. It may also be stamped on the meter body for positive displacement types.
Do not confuse raw K factor with scaled pulses per unit. Some transmitters allow a user defined pulse output. For example, you can set one pulse per 10 litres. That scaled output is not the physical K factor of the primary sensor. Keep both values in the commissioning sheet.
Which Silver Instruments Flow Meters Need K Factor Verification
Pulse output meters benefit from K factor checks. This includes oval gear flow meters, turbine flow meters, vortex flow meters, and positive displacement meters. Electromagnetic flow meters and Coriolis mass flow meters can also emit a pulse output, but their K factor is often configured in the transmitter electronics rather than derived from a mechanical rotor.
For a 25 mm diesel line with 4.5 cP viscosity, select a Silver Instruments OGM series oval gear flow meter with pulse output, 4-20 mA HART, PN16 flanges, and a flow range of 1 to 10 cubic metres per hour. The OGM series covers DN15 to DN80 for diesel and light oil. For a 100 mm clean water line, select a Silver Instruments turbine flow meter with DN100, pulse output, 4-20 mA HART, PT100 temperature input, and an accuracy class of plus or minus 0.5 percent of reading.
What Affects K Factor Accuracy
Viscosity is the biggest variable for turbine flow meters. A turbine meter calibrated on water will show a different K factor on 20 cP oil. Oval gear meters are less sensitive to viscosity but they still need a K factor check if the fluid lubricity changes. Air entrainment causes positive displacement meters to over register. Pipe vibration can create false pulses on vortex meters.
Temperature changes the meter body and rotor clearance in some mechanical designs. Pressure changes are usually minor for liquid meters, but they matter more for gas and steam. A chemical plant in Saudi Arabia saw a 0.7 percent K factor shift on a turbine meter when the process temperature moved from 25 to 55 degrees Celsius.
FAQ: Flow Meter K Factor Calculation
What is the formula for K factor in a flow meter?
K factor equals total pulse count divided by exact volume collected. Units are pulses per litre or pulses per gallon.
How many test points should I use for K factor verification?
Three test points at minimum flow, normal flow, and maximum flow. If the linearity is within plus or minus 0.5 percent of average, use the average K factor.
Can I use the flow meter display volume to calculate K factor?
No. The display already uses the existing K factor. Use a calibrated prover tank, weigh scale, or master meter.
Which flow meter type needs K factor verification most often?
Turbine flow meters and vortex flow meters need K factor checks because viscosity, flow profile, and vibration affect their pulse output. Oval gear meters are more stable but still need field checks after installation.
What should I send for a K factor compatible flow meter quote?
Send your fluid, viscosity in cP, operating pressure in bar, temperature in degrees Celsius, pipe size in DN, and flow range. We will recommend a pulse output model and K factor range.
For a specific recommendation, contact Silver Automation Instruments. Send your fluid type, operating pressure in bar, temperature in degrees Celsius, pipe size in DN, and minimum to maximum flow rate. Specify if the meter is for ATEX Zone 1 or a safe area installation. Call +86-25-68650347, WhatsApp +86-25-52155837, or WeChat +86 15365082610. We can provide a calibration sheet and the correct K factor for your application.
