『How to Set an Oxygen Flow Meter: Adjustments to medical oxygen flow should only be made according to a healthcare provider’s prescription using the integrated control valve.』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Quick Answer: Industrial oxygen flow meters need correct pressure, temperature, pipe size and flow range before startup. Medical oxygen flow adjustments should only be made according to a prescription from a healthcare provider using the integrated control valve. Silver Instruments supplies industrial oxygen flow meters for gas, chemical and water treatment plants.
What an Oxygen Flow Meter Does in Industrial Service
An oxygen flow meter measures gas mass flow in kg/h or standard cubic meters per hour. In water treatment, chemical plants and gas mixing skids, operators rely on flow meters with 4-20 mA HART output and local display. Silver Instruments supplies Coriolis mass flow meters, thermal mass flow meters and vortex flow meters for oxygen gas lines from DN15 to DN200.
Medical oxygen flow meters are different from industrial devices. A medical unit uses an integrated control valve and requires a healthcare provider prescription. Industrial devices do not replace medical oxygen therapy equipment.
Step-by-Step Setup for Industrial Oxygen Flow Meters
First, confirm the pipe size and flow range. A thermal mass flow meter suits low flow rates from 0.1 kg/h to 100 kg/h. A Coriolis mass flow meter suits 50 kg/h to 10,000 kg/h depending on line size.
Second, check pressure and temperature. Oxygen gas lines often run at 4 bar to 20 bar and from 10 °C to 50 °C. Select a flow meter rated for the maximum working pressure. For oxygen service, all wetted parts must be free of oil and grease.
Third, install the flow meter with straight pipe runs. Most manufacturers recommend 10 DN upstream and 5 DN downstream for vortex flow meters. Thermal mass flow meters tolerate shorter straight runs in compressed air and oxygen lines.
Fourth, wire the 4-20 mA HART output to the control room. Configure the range, units and totalizer in the local display. Use density correction for mass flow devices if line pressure changes by more than 2 bar.
Key Parameters: Pressure, Temperature, DN Size and Flow Range
Here is the thing. Gas flow readings drift when pressure compensation is missing. We have seen this on customer sites many times. A paint manufacturer in Southeast Asia specified a DN50 oxygen flow meter for a 2 kg/h pilot line. The flow was below the vortex meter cutoff and the reading stayed at zero. We replaced it with a thermal mass flow meter for low flow oxygen.
Send us your pressure in bar, temperature in °C, pipe size in DN and flow range in kg/h. We will recommend a flow meter with the right turndown ratio and wetted parts for oxygen.
Medical Oxygen Flow Adjustment Warning
Adjustments to medical oxygen flow should only be made according to a prescription from a healthcare provider using the integrated control valve. Industrial flow meters are not designed for patient use. Do not use Silver Instruments flow meters for medical oxygen therapy or hospital gas delivery to patients.
If you need a flow meter for industrial oxygen storage, cylinder filling or gas mixing, we can help. Tell us the application and gas puri
Common Installation Mistakes on Customer Sites
Most engineers skip the oil-free cleaning check. Oxygen reacts with oil and grease. Even a small residue can cause a safety risk. Always request oxygen cleaning for wetted parts, especially for pressures above 20 bar.
Another common mistake is using a liquid flow meter for gas. A rotameter with a stainless steel float for water will not read correctly on oxygen gas. Specify gas calibration and the actual gas composition.
Last year a customer in Vietnam asked us for a seawater flow meter for a desalination plant but later needed oxygen flow measurement for ozone generation. We supplied a thermal mass flow meter with Hastelloy wetted parts. The unit has run without drift for 8 months.
Recommended Flow Meter Types for Oxygen Gas
For oxygen flow from 0.1 kg/h to 200 kg/h, a thermal mass flow meter gives good low flow sensitivity. For 200 kg/h to 10,000 kg/h, a Coriolis mass flow meter works well if the line stays full and pressure is stable. Vortex flow meters suit larger pipe sizes from DN40 to DN200 but need enough flow velocity.
Oval gear flow meters are not recommended for gas. They are built for liquids like diesel, fuel oil or chemicals. Use a gas-specific device for oxygen.
How to Specify an Oxygen Flow Meter to Silver Instruments
Send us these details: pressure in bar, temperature in °C, pipe size in DN, flow range in kg/h, gas composition, oxygen purity, signal output and hazardous area class. If the site is ATEX Zone 1 or Zone 2, we will quote an Ex-proof flow meter.
Contact Silver Instruments at Tel: +86-25-68650347. WhatsApp: +86-25-52155837. WeChat: +86 15365082610. Our sales engineers respond to industrial flow meter inquiries from Southeast Asia, Oceania, Latin America, Africa and the Middle East.
FAQ: Oxygen Flow Meter Setup
1. Can I use a medical oxygen flow meter for industrial gas lines? No. Medical oxygen flow meters use an integrated control valve and are calibrated for patient use. Use an industrial thermal mass or Coriolis flow meter.
2. What is the minimum flow rate for an industrial oxygen flow meter? A thermal mass flow meter can measure from 0.1 kg/h in DN15 lines. Vortex meters often need higher flow velocity. Send your flow range for a specific model.
3. Do you supply oil-free oxygen cleaned flow meters? Yes. We mark oxygen cleaning as a separate requirement. Wetted parts are cleaned and bagged before shipping.
4. Can you quote a flow meter for ATEX Zone 1 oxygen service? Yes. Give us the gas group, temperature class and zone. We will select an Ex-proof thermal mass or Coriolis flow meter.
5. What signal output works best for oxygen flow totalizing? 4-20 mA HART is common for process control. Pulse output works for totalizing. Most Silver Instruments flow meters support both.
Need a quote for an oxygen gas flow meter? Send us your pressure in bar, temperature in °C, pipe size in DN and flow range in kg/h. We will reply with a model and price.
