『handheld flow meter|air flow meter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1.Handheld Digital Ultrason
High quality Handheld Ultrasonic Flow Meter with Clamp On Ultrasonic Flowmeter -HUF2000-H incorporates the latest ICs manufactured from the famous semiconductor manufacturers like Philips, Maxim, TI, Winbond, an
2.Handheld Water Flow Meter
Handheld Water Flow Meter Portable Ultrasonic Flow Meter --Price for dn15mm~dn700mm pipe size, 4-20mA Product Description UF2000 ultrasonic flowmeter has been manufactured with patent technologies and is equipped with more functions and advanced performance than our previous versions. ...
3.Handheld Ultrasonic Water
Handheld Ultrasonic Water Flow Meter Tds Metertds-100H --Price for dn15mm~dn700mm pipe size, 4-20mA Product Description UF2000 ultrasonic flowmeter has been manufactured with patent technologies and is equipped with more functions and advanced performance than our previous vers...
4.Handheld Ultrasonic Flow
ACE METER TECHNOLOGY CO., LIMITED Trading Company Rating 5.0 Diamond Member Since 2020 Audited Supplier Fast Delivery Low MOQ Quality Assurance 100% Finished Pr
5.RS-232 Serial Interface H
High quality Handheld Ultrasonic Flow Meter with Clamp On Ultrasonic Flowmeter -HUF2000-H incorporates the latest ICs manufactured from the famous semiconductor manufacturers like Philips, Maxim, TI, Winbond, and Xilinx. The hardware features the ease of operation, high accuracy and...
6.HFUM Handheld Ultrasonic
HFUM handheld ultrasonic flow meter is designed to work with clamp-on sensors to measure the liquid flow within a closed pipe without any insertion mechanical parts. Mainly be used for routing inspection or pipe monitoring, very convenience for use. It is controlled by a micro-processor system ...
7.Handheld Ultrasonic Flow
Handheld Ultrason... Portable Ultrason... Electromagnetic F... GLP2000 Pressure ... GLP2881 Liquid Le... GLP-TDS-100H Handheld Ultrasonic Flow Meter I、Overview : II、Basic Technical Parameters
1、Installation ways u Clamp on type, it is simple and convenient for operation.
2、Medium ...
