Explosion proof vortex flowmeter
Technical parameters of vortex gas flowmeter | What are the types of volumetric flow type air flowmeters and what are their characteristics? | Requirements for straight pipe sections before and after installation of various flow meters | Main characteristics and technical parameters of natural gas flowmeters|
Keywords:Technical parameters of vortex gas flowmeter | What are the types of volumetric flow type air flowmeters and what are their characteristics? | Requirements for straight pipe sections before and after installation of various flow meters | Main characteristics and technical parameters of natural gas flowmeters|
Company:Supply from Lianyungang water flow meter manufact
『Explosion proof vortex flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. The difference between turbine flowmeter and vortex flowmeter should be explained in detail and comprehensively.
KNKE, a well-known American imported flowmeter brand with good customer reputation and fast delivery time, answers your question.
1. Differences in application fields: Vortex flowmeter slag: mainly used for flow measurement of industrial pipeline media fluids, such as gas, liquid, vapor and other media.
. Its characteristics are small pressure loss, large range, high accuracy, and almost unaffected by parameters such as fluid density, pressure, temperature, viscosity, etc. when measuring volumetric flow rate under working conditions. Without any movable mechanical parts, the macro beam has high reliability and low maintenance. The instrument parameters can be stable for a long time. Turbine flowmeter: widely used for measuring objects such as petroleum, organic liquids, inorganic liquids, liquefied gas, natural gas, coal gas, and low-temperature fluids. It has a simple structure, few processed parts, light weight, easy maintenance, high flow capacity (the same caliber can pass through a large flow rate), and can adapt to high parameters (high temperature, high pressure, and low temperature). 2. Differences in Production and Manufacturing: A turbine flowmeter is an instrument that uses a multi blade rotor (turbine) to measure the average flow rate of a fluid and calculate the flow rate or total flow rate accordingly. The vortex flowmeter is designed and manufactured based on the Karman vortex principle. Measure flow rate using the principle of fluid oscillation. When the fluid passes through the vortex transmitter in the pipeline, the triangular vortex generator alternately generates tw
o rows of vortices in proportion to the flow rate. The release frequency of the vortex generator is related to the average velocity of the fluid flowing through the vortex generator and the characteristics of the vortex generator. Thirdly, the difference in data transmission is that the turbine flowmeter cuts off the magnetic induction line by rotating the impeller, and then measures the output flow rate through signal processing. Vortex flowmeter is a flow measurement method that processes the output signal by detecting the Karman vortex street. If you think the answer is helpful to you, please kindly give a thumbs up to the American manufacturer of KNKE flow meters! If you have a purchasing need for flow meters, please visit the official website of KNKE in the United States for selection and procurement, or inquire with KNKEs professional technical personnel to find the most suitable product for you.
2. Main features and technical parameters of natural gas flow meters
The main features of natural gas flow meters include: high measurement accuracy: manufactured using the Karman vortex street principle to ensure the accuracy of measurement results.
. Wide range: The dynamic measurement range is wide, with a range ratio of 1:10, suitable for measurement needs in different flow ranges. Low power consumption: The power supply method is flexible, including built-in lithium batteries and external power sources, and the power consumption is relatively low. Easy installation: There are no moving parts inside the instrument, making the installation process simple and fast. Easy to operate: The dashboard displays rich content, including cumulative flow, instantaneous flow, etc., making the operation intuitive an
