『Elbow Flow Meter Working Principle and Differential Pressure Equations』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Quick Answer: An elbow flow meter turns an existing 90 degree pipe bend into a differential pressure element. It reads pressure from the outer and inner radius of the elbow. Flow rate is calculated from the square root of this differential pressure.
How an Elbow Flow Meter Works
In a 90 degree pipe elbow, fluid follows a curved path. Centrifugal force pushes the fluid toward the outside radius. This creates a higher pressure on the outer wall and a lower pressure on the inner wall. An elbow flow meter uses two small pressure taps in the same cross section. One tap sits on the outside radius. The other tap sits on the inside radius.
A differential pressure transmitter reads the two pressures. The measured dP value is proportional to the dynamic pressure of the flowing fluid. Because there is no added orifice or wedge, the meter adds almost no permanent pressure loss to the line. This is a key reason why plants use elbow meters on large lines or abrasive fluids.
Most elbow flow meters are installed on existing elbows. They are not separate flow elements. This reduces capital cost and avoids cutting a pipe when a long straight run is already available.
Differential Pressure Equations for Elbow Flow Meters
The basic elbow flow meter equation is shown below.
Equation 1: dP = K x rho x V x V / 2
In this equation, dP is differential pressure in Pascal. K is the elbow coefficient. rho is fluid density in kg/m3. V is average pipe velocity in m/s.
K is determined by elbow geometry, tap location, and flow conditions. For a standard 90 degree elbow with pressure taps at 45 degrees, K often ranges from 0.6 to 2.2. Field calibration brings K closer to actual site conditions.
Flow rate is derived from the same dP signal.
Equation 2: Q = A x C x sqrt(2 x dP / rho)
Equation 3: W = A x C x sqrt(2 x rho x dP)
In these equations, Q is volumetric flow rate in m3/s. W is mass flow rate in kg/s. A is pipe cross sectional area in m2. C is the flow coefficient. You can think of C as the square root of 1 over K.
Here is a practical water example. Take a DN150 pipe with an internal diameter of 154 mm. Water at 30 degrees Celsius has a density of 995 kg/m3. At 120 m3/h, the average velocity is about 1.79 m/s. If K is 1.3, the calculated dP is 1.3 x 995 x 1.79 x 1.79 / 2. That gives about 2072 Pa or 20.7 mbar. A DP transmitter ranged from 0 to 100 mbar works well for this application.
For gas or steam, density changes a lot with pressure and temperature. You need to correct rho in the flow equation. Most sites use a pressure transmitter, a PT100 temperature sensor, and a flow computer or PLC for this correction.
Accuracy and Calibration
An elbow flow meter is not a high accuracy device. Typical accuracy is 1 to 5 percent of full scale. Repeatability is often better than the absolute accuracy. The meter works well for balance measurement, pump monitoring, cooling water, and process indication. It is not recommended for custody transfer.
Accuracy improves if the elbow coefficient is calibrated on site. A clamp on ultrasonic flow meter can provide a reference flow value. You can then adjust K in the flow computer until the elbow meter output matches the reference. We have seen this done on a pump discharge line in Vietnam. The plant reduced error from about 4 percent to 1.5 percent after a one day calibration.
The Reynolds number also affects K. Below a pipe Reynolds number of about 100 000, the coefficient may shift. For viscous fluids or low velocity lines, expect larger error.
Installation and Tap Location
Pressure taps are normally located in the elbow at 45 degrees from the inlet face. The ou
For liquid service, mount the DP transmitter below the pressure taps so bubbles can vent back into the process line. For gas or steam, mount the transmitter above the taps so condensate drains back. Use a three valve manifold for zero checks.
The upstream straight run recommendation depends on the flow profile. Most elbow flow meters work better with at least 10D to 20D of straight pipe upstream and 5D downstream. If an upstream valve or pump is too close, the dP signal may shift.
Application Fit for Elbow Flow Meters
Elbow flow meters are common in water and wastewater plants, desalination plants, cooling water circuits, and slurry transfer lines. They handle solids better than an orifice plate because there is no edge to clog or wear.
In the Middle East, desalination plants use elbow meters on brine return lines. Salt slurry and scale are less likely to build up around two small taps than around a venturi or an orifice plate. In Southeast Asia, palm oil and wastewater plants use elbow meters on raw feed lines where debris is common.
A cooling water line in Indonesia is a typical example. The pipe is already DN300 and has a 90 degree elbow before a heat exchanger. Adding an elbow flow meter requires only two tap holes and a DP transmitter. No pipe cutting and no added pressure loss.
Model Pairing with Silver Instruments
Silver Automation Instruments supplies elbow flow meters in DN25 to DN600 as standard. Larger sizes are available on request. Body materials include carbon steel and stainless steel 304 or 316L. Process connections are usually 1/4 inch NPT or 1/2 inch NPT.
For the DP signal, pair the elbow meter with our differential pressure transmitter. Standard output is 4-20 mA HART. Ranges start from 0 to 60 mbar and go up to 0 to 40 bar. Optional ATEX Zone 1 or Zone 2 housings are available. For gas or steam flow, add our pressure transmitter and PT100 temperature sensor. The flow computer or PLC can then correct density in real time.
We have supplied this package to food and beverage plants in Thailand, water plants in the Philippines, and oil and gas water lines in Nigeria. The typical order includes one elbow meter body, one DP transmitter, one three valve manifold, and two impulse line kits.
What is the accuracy of an elbow flow meter? Accuracy is normally 1 to 5 percent of full scale. It is best for process control and monitoring. It is not recommended for custody transfer.
Can an elbow flow meter measure gas or steam? Yes. You must add pressure and temperature compensation because gas density changes with process conditions. Use a DP transmitter, pressure transmitter, and PT100 sensor.
What tap orientation is required? Use two taps at the same elbow cross section, usually at 45 degrees. One tap is on the outside radius. The other is on the inside radius.
How much straight run does an elbow flow meter need? Try to provide 10D to 20D upstream and 5D downstream. Exact requirements depend on the flow profile and upstream devices.
What maintenance does an elbow flow meter need? Maintenance is low. The main tasks are rodding the impulse lines if the fluid is dirty, checking zero on the DP transmitter, and inspecting the taps for blockage.
Need a selection for your next water, steam, or slurry line? Send us your pressure in bar, temperature in °C, pipe size in DN, and flow range in kg/h or m3/h. We will recommend the right elbow flow meter and differential pressure transmitter. Tel: +86-25-68650347. WhatsApp: +86-25-52155837. WeChat: +86 15365082610. Visit flow-meter.com.au.
