『Low Flow Meter For Laboratory Ml/Min Analytical Standards』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Low Flow Meters for Laboratory: mL/min Analytical Standards
Quick Answer: For lab dosing at 0.1 mL/min to 500 mL/min you need a Coriolis or oval gear meter from Silver Instruments, not a general-purpose turbine. We ship with actual calibration data traceable to ISO 17025 and wetted parts in 316L, Hastelloy C-22, or PEEK for aggressive reagents. Tell us your liquid, viscosity in cP, pressure in bar, and pipe size we normally use 1/8 inch or DN2 connections.
Why Most Lab Flow Meters Give Wrong Numbers
We have seen this on customer sites many times. A research chemist in Bangkok ordered a mass flow controller for microflow and got a sensor that drifted 3 % after two weeks with acetonitrile. In analytical labs what kills repeatability is not the sensor alone but the mismatch between fluid and wetted material plus zero stability at very low flow. A standard metal tube rotameter cannot hold 0.5 % accuracy at 5 mL/min for low-viscosity solvents. Silver Instruments builds dedicated low-flow meters for this exact job.
Here is the thing. When you inject internal standard into a GC or dose catalyst into a microreactor, the signal must stay flat. Even a 0.1 mL/min offset changes the peak area ratio. That is why we configure each meter with a factory calibration run using water or the customer-specific fluid at 20 °C or 25 °C, so you get a certificate with 5-point check data straight out of the box.
Coriolis Mass Flow Meters for Ultralow Liquid Flows
Our Coriolis sensor uses a small bent tube design that directly measures mass in g/min, so density changes do not ruin the reading. A typical model, the SI-CMF-0.2, starts from 0.1 mL/min and goes up to 200 mL/min. Accuracy on mass flow is ±0.2 % of rate, repeatability ±0.05 %, and it works up to 150 °C process temperature with a standard 100 bar rating. The wetted part can be 316L or Hastelloy C-22 if your analytical method involves nitric acid or hot sulfuric acid. Signal output is 4-20 mA HART plus RS485 Modbus RTU, which connects directly to any lab DAQ system or PLC.
In practice, a cosmetic quality control lab in Malaysia uses three SI-CMF-0.2 meters to blend fragrance oils at 2.5 mL/min into a carrier cream. They log mass flow every 1 second and trigger an alarm if the deviation exceeds ±0.3 %. Before they switched to Silver Instruments they wasted 150 kg of raw material per month due to in-line spiking errors.
Oval Gear Flow Meters for Viscous Analytical Samples
For viscous liquids above 10 cP we often recommend an oval gear positive displacement meter. It costs less than a Coriolis and does not need a straight pipe run. The SI-OG-01 handles 0.5 to 50 mL/min with ±0.5 % of reading for oils, polymers, and resin hardeners. The gears come in PEEK and the housing in 316L, with EPDM or PTFE O-rings. Maximum viscosity we have tested is 5000 cP on a gear coating test bench in Brazil, and the meter held repeatability to 0.2 % after a 30-minute flush cycle.
A calibration lab in Egypt runs an automatic titrator that doses silicon oil at 10 mL/min. They used a glass syringe pump for years but the seal wore out every 2 months. With the SI-OG-01 and a pulsed output they now run 14 hours a day with zero maintenance for 18 months and counting. Because the meter gives a raw pulse per 0.001 mL, it fits directly into lab software that counts pulses for totalized volume.
Key Specs to Check Before You_600x400.jpg)
Buy
Most engineers skip this part and end up with a meter that is either too large or attacked by the solvent. When you quote, list these five parameters:
Minimum and maximum flow in mL/min or g/min. The turndown ratio on our SI-CMF-0.2 is 1000:1 so you can cover a wide range but if you only need 0.05 to 2 mL/min we can use a smaller tube.
Fluid name and approximate viscosity at working temperature. Methanol at 25 °C is 0.5 cP, glycerine at 20 °C is 1400 cP. This decides the technology.
Process pressure and temperature. Standard models go to 100 bar and 150 °C; for high-temperature labs we offer a version up to 300 °C with remote electronics.
Wetted material compatibility. We keep stock in 316L, Hastelloy C-22, and PEEK. For hydrogen peroxide or strong acids we swap to titanium.
Output signal: 4-20 mA HART, pulse, or Modbus. Most analytical setups already have a 4-20 mA input card. No extra converter needed.
Integration with Analytical Instruments and Data Logging
The output from our low flow meter is not raw sensor voltage. It is already processed and linearized. Connect the 4-20 mA HART terminals to a recorder, PLC, or a simple panel meter. The HART digital signal gives you mass flow, temperature, and diagnostic error codes over two wires. For labs that run 21 CFR Part 11 compliant software, we supply a USB-to-RS485 adapter and a Modbus map document so you can poll the meter every 200 ms.
A pharmaceutical R&D team in South Africa integrated four SI-CMF-0.2 meters into their continuous flow synthesis rig. They pull mass flow data into a Python script that controls a back-pressure regulator. The closed-loop adjusts to maintain stoichiometric ratio within ±0.15 %. The whole thing cost less than one third of a commercial flow chemistry package.
How to Order a Low Flow Meter Quote
Send us your required flow range in mL/min, fluid name, viscosity in cP, pressure in bar, temperature in °C, and connection size. If you have a specific analytical standard like ISO 6358 or ASTM D1250, mention it. Our engineers will reply within 12 hours with a recommended model, dimensional drawing, and a calibration certificate option. Email [email protected] or use the inquiry form on flow-meter.com.au. The website has a dedicated menu for "Low Flow Meters" with datasheets and pricing brackets.
What is the lowest measurable liquid flow rate? 0.05 mL/min with our SI-CMF-0.05 sensor. For gas we go down to 0.2 mLn/min with a thermal mass meter.
Can the meter handle aggressive chemicals like fuming sulfuric acid? Yes, we use Hastelloy C-22 wetted parts and PTFE seals. Please specify the exact concentration and temperature when you request a quote.
Do you provide ISO 17025 calibration for laboratory audits? Yes, we offer an accredited calibration certificate as an extra line item. Standard meters come with a 5-point factory calibration report traceable to NIST.
What power supply does the low flow meter need? 12 to 24 VDC, under 2 watts. For loop-powered 4-20 mA HART it runs on the same two wires that carry the signal.
How long is the delivery time for a lab meter? We ship standard models within 5 business days from our Melbourne or Singapore warehouse. Custom wetted parts or high-pressure adapters take 3 weeks.
