How Does an Orifice Flow Meter Work: Forces fluid through a sharp-edged restrictor plate, deriving flow from the resulting drop in pressure.
niotall8988f
DateTime 09/16/2026 Show 16
Keywords:How Does an Orifice Flow Meter Work: Forces fluid through a sharp-edged restrictor plate, deriving flow from the resulting drop in pressure.
Company:Taian wastewater flowmeter manufacturer
『How Does an Orifice Flow Meter Work: Forces fluid through a sharp-edged restrictor plate, deriving flow from the resulting drop in pressure.』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Quick Answer: An orifice flow meter forces liquid, gas, or steam through a sharp-edged restrictor plate with a bored hole. The plate creates a pressure drop between the upstream and downstream taps. A differential pressure transmitter converts that drop into a flow rate.
Silver Instruments supplies orifice flow meter packages for DN15 to DN600 lines. For a quote, send your fluid type, pressure in bar, temperature in °C, pipe size DN, and flow range.
Working Principle and the Role of the Sharp Edged Plate
Flow enters the pipe and hits the orifice plate. The plate has a sharp edge on the inlet side and a bored hole in the center. Fluid accelerates through the hole. Velocity rises and static pressure falls. This is the Bernoulli effect in action.
Downstream of the plate, the fluid decelerates. Pressure recovers but not fully. The permanent pressure loss depends on the plate bore and the beta ratio. Beta ratio is the hole diameter divided by pipe internal diameter.
What the Pressure Drop Tells You
The upstream tap measures higher pressure. The downstream tap measures lower pressure. The difference is called differential pressure or DP. Flow rate is not linear with DP. Flow rate is proportional to the square root of DP.
For example, a DP of 25 mbar does not mean five times the flow of 5 mbar. It means roughly 2.24 times the flow. A 4 to 20 mA HART DP transmitter usually needs a square root function in the PLC or flow computer.
Key Formula and Practical Calculations
The basic calculation uses Q = C times the square root of Delta P divided by density. C is the discharge coefficient from ISO 5167 or AGA 3. Density comes from pressure, temperature, and gas composition tables.
A gas line at 10 bar with a 0 to 100 mbar DP range behaves differently than a water line at the same DP. Always calculate the flow equation at actual operating density, not standard density. Most engineers skip this part and get errors at low flow.
Typical Accuracy and Turndown for Orifice Flow Meters
Orifice flow meters are not the highest accuracy devices on the market. But they are rugged and repeatable. A standard sharp-edged plate with flange taps gives about plus or minus 0.5 to 1.5 percent of rate. Turndown is often 3:1 or 4:1.
In practice, a plate sized for 0 to 100 m3/h will not read 1 m3/h well. DP noise becomes large at the bottom end. That is why many sites keep orifice meters on steady loads like boiler feedwater, fuel gas, steam headers, and compressor discharge.
Common Applications in Industrial Plants
We have seen these meters in many industries. A paint manufacturer in Vietnam uses a DN50 orifice plate on a solvent line at 5 bar and 25°C. A desalination plant in Oman uses a DN300 plate on brine discharge. A gas distribution site in Nigeria uses orifice plates on a 20 bar fuel gas header.
Other typical applications include steam flow for boilers, natural gas flow for burners, air f
low to aeration basins, and liquid flow in low cost water lines. Orifice meters work well when the flow is steady and the pipe is full.
Installation Notes That Most Engineers Learn the Hard Way
An orifice plate needs straight pipe upstream and downstream. A DN100 plate with a beta ratio of 0.6 may need 22D upstream and 7D downstream. If you install the plate after a partially closed valve or an elbow, the velocity profile is distorted. Accuracy drops fast.
Check the sharp edge during installation. The inlet edge must be square and sharp. A worn edge causes a lower DP reading. The meter reads low and the plant burns more fuel or sells less gas. We have seen this on customer sites many times.
For steam service, use impulse lines with condensate pots. For gas service, slope the impulse lines upward to the transmitter. For liquid service, slope them downward. Freezing is a real risk in cold areas. Use heat tracing and insulated impulse lines at 4°C ambient or below.
Recommended Pairing from Silver Instruments
Silver Instruments offers the orifice plate, flange taps, DP transmitter, three-valve manifold, and condensate pots as one package. The transmitter uses 4 to 20 mA HART output. You can size the plate for DN15 to DN600 and pressure up to PN100 or ANSI 600.
The plate material can be 316L stainless steel, Hastelloy, or Monel. For seawater desalination service, ask for super duplex or 316L with PTFE gaskets. For high temperature steam above 300°C, we use 316L or alloy plates with pressure ratings to match. Tell us the actual operating density, viscosity in cP, and pipe schedule.
FAQ: Orifice Flow Meter Questions
Which fluids can an orifice flow meter measure?
Liquid, gas, and steam. Clean or dirty fluids can pass through a plate, but slurries can damage the sharp edge. Avoid fluids with solids unless you inspect often.
How much straight pipe does an orifice flow meter need?
A common range is 10D to 30D upstream and 5D to 8D downstream. The exact value depends on the fitting before the meter and the beta ratio. Follow ISO 5167 for your layout.
Can an orifice plate handle high temperature steam?
Yes. With 316L plates and proper impulse lines, orifice meters handle steam above 300°C. But the DP transmitter must be protected from direct steam heat.
How often should orifice plates be inspected?
In clean gas or liquid service, inspect every 12 to 24 months. In dirty service or high velocity flow, check every 6 to 12 months. Look for edge wear, deposits, and gasket leaks.
Can Silver Instruments supply a full orifice flow meter package?
Yes. Send your pressure in bar, temperature in °C, pipe size DN, and flow range. Tel: +86-25-68650347. WhatsApp: +86-25-52155837. WeChat: +86 15365082610.
Silver Automation Instruments supplies industrial orifice flow meters, differential pressure transmitters, and flow metering packages. You can order a replacement plate or a complete metering run.
