『Thermal Gas Mass Flow Meter for Flare Gas Lines』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Quick answer: A thermal gas mass flow meter measures flare gas directly in mass units like kg/h or Nm3/h. No separate pressure or temperature transmitters are needed. This single instrument handles the wide flow swings and low velocities typical of flare headers, and it keeps working when gas composition shifts.
What Makes Thermal Mass Measurement Fit Flare Applications
Flare gas lines are tough. Flow can swing from near zero during normal operation to a sudden surge when a relief valve lifts. The gas composition is rarely pure methane. You may get hydrogen, nitrogen, butane, or moisture sneaking in, all at the same time. A thermal mass flow meter reads mass flow directly by measuring the cooling effect on a heated sensor. Two platinum RTD sensors sit in the gas stream. One tracks process temperature. The other is heated and maintained at a constant temperature difference above the gas. The more mass flows past the heated sensor, the more heat it draws away. This principle gives you a reading in Nm3/h or kg/h without needing to know exact density.
We have seen this work on flare headers ranging from DN80 to DN600. The meter inserts through a 1.5 inch ball valve, so you do not have to shut the flare down for installation. The sensor tip reaches the center of the pipe where velocity is highest. For lines smaller than DN50, we usually supply an in-line spool piece instead of an insertion probe. Most engineers skip trying to use differential pressure devices here. An orifice plate clogs easily, and the square-root relationship kills low-end resolution. A thermal meter holds a turndown of 100:1 or more, which matters when you need to quantify small continuous purges and also catch a 50 ton-per-hour emergency vent.
Practical Points Before You Mount It on a Flare Stack
Mounting location decides how much maintenance you will do later. On wet flare gas that carries droplets from a knockout drum, the sensor needs a drip loop so condensate does not pool on the heated element. In practice, we recommend installing the meter on a horizontal run at least 15 diameters downstream of any elbow or valve. A site in Indonesia learned this the hard way. They placed the meter right after a 90-degree bend and kept seeing a 10 percent offset during purge conditions. After moving it to a straight section, the reading stabilized within 1 percent of expected purge rate.
Temperature and pressure ratings matter. For a standard petroleum refinery flare in the Middle East, we often supply sensors rated for -40 °C to +120 °C process temperature and up to 10 bar. If your plant flares heavier hydrocarbons or handles high gas temperatures during decoking, specify a sensor head that handles 200 °C and 16 bar. The electronics housing can be remote-mounted up to 50 meters away, which helps when the meter head sits on a platform under full sun. For hazardous areas, all our thermal mass flow meters for flare lines come with ATEX Zone 1 or IECEx Ex d certification. Output is always 4-20 mA HART, so it drops into your existing DCS or RTU without a fight.
Real Installations and What They Taught Us
A Vietnamese gas terminal put our insertion thermal meter on a DN250 flare collecting tank boil-off and intermittent overpressure events. Their goal was custody-approved reporting to local environmental authorities. The meter replaces a sonic nozzle system that required constant recalibration. After six months, the maintenance log shows zero drift and two simple sensor cleanings with a soft brush. The 4-20 mA signal goes straight into a Silver Instruments paperless recorder, and from there data heads to a government server via Modbus TCP.
In a different setting, a chemical plant in Brazil uses in-line thermal meters on four small flare headers, each DN40. The combined flow goes to a ground flare. They needed to isolate the source of unexpected high emissions during night shifts. The inline meters,
Key Specs You Should Ask For
When you request a quote for a flare thermal mass meter, skip the generic part numbers. State the pipe diameter in DN, the minimum and maximum flow rates, normal operating pressure in bar, gas temperature range in °C, and the main gas components. That way we select the right probe length, sensor alloy, and power supply. For flare lines with potential hydrogen or wet sour gas, we offer Hastelloy C276 sensor construction. Standard sensor material is 316L stainless steel, which works fine for clean natural gas flares. Low flow sensitivity is one specification that gets overlooked. You want the meter to accurately measure purge rates around 0.05 Nm/s to 0.1 Nm/s, not just the fire emergency vent. Be clear about that during inquiry.
Can a thermal mass flow meter handle varying gas mixtures in a flare?
It can, but you must tell the factory what the expected range is. The meter measures mass flow based on heat transfer, which changes with gas thermal conductivity and specific heat. A unit calibrated for methane will read differently with hydrogen present. We build a custom calibration curve if the mixture changes within a known envelope. Many operators send us a typical gas chromatograph analysis and three worst-case compositions. The accuracy then stays within 2 percent of reading across the full range.
Will condensate or tar ruin the sensor?
Liquid droplets striking a hot sensor cause a momentary spike, but they do not immediately destroy it. In dirty flare service, however, buildup can form. We specify a purge port that lets you clean the sensor without removing it from the pipe. In heavy tar flaring, we have seen customers set a weekly cleaning routine using solvent injection through that port. With a dirty gas, pick a meter with a removable probe and specify a ball valve for retraction.
How does this meter compare with ultrasonic or vortex on flare lines?
Vortex meters lose signal at low flow and require Reynolds number limits. Ultrasonic meters can work but typically cost three times more for large pipe diameters and still need a clean gas path. Thermal mass gives you a direct mass reading with no moving parts and low installation cost. Here is the thing: for lines that stay above 5 m/s most of the time, vortex might be enough. But on a flare line where 90 percent of the time velocity is below 1 m/s, thermal mass is the field-proven choice.
What approvals does Silver Automation Instruments hold for flare gas metering?
Our thermal mass flow meters carry ATEX, IECEx, and SIL 2 certifications for use in Zone 1 hazardous areas. The transmitter housing meets IP67. For regions like Australia, we also offer meters with IECEx standards recognized by local regulators. All meters ship with a 5-point calibration certificate traceable to NIST or equivalent.
Can I test the meter on my flare before buying?
We arrange a trial unit for a period of two weeks up to one month depending on your location. We ask that you cover the freight cost. The trial includes a local display, 4-20 mA output, and remote support from our application team during setup. We have done trials at LNG terminals in Malaysia, a fertilizer plant in Qatar, and a waste-to-energy site in Australia. Email us your process data and we will suggest a trial configuration.
For a specific price and delivery time for a thermal gas mass flow meter on your flare line, send us your pipe size (DN), gas pressure (bar), temperature (°C), normal and maximum flow range (kg/h or Nm3/h), and details about the gas composition. A technical proposal including dimensional drawings and accuracy curves will follow within two working days.
