Bronkhorst Thermal Mass Flow Meter: Sourcing Cleanroom Vapor Delivery Manuals
Effevtive Time:8/18/2026
Keywords:Bronkhorst Thermal Mass Flow Meter: Sourcing Cleanroom Vapor Delivery Manuals
『Bronkhorst Thermal Mass Flow Meter: Sourcing Cleanroom Vapor Delivery Manuals』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Bronkhorst Thermal Mass Flow Meter Sourcing and Cleanroom Vapor Delivery Manuals
Quick Answer: Bronkhorst thermal mass flow meters are often specified for cleanroom vapor delivery because they measure low vapor mass flow directly in kg/h or standard liters per minute. Manuals from Bronkhorst list zero point checks, purge procedures, wiring, and error codes for water vapor, IPA vapor, and specialty gas lines. Silver Instruments supplies thermal mass flow meters with 4-20 mA HART output for DN15 to DN50 cleanroom vapor lines, usually with a shorter lead time.
Why Cleanroom Vapor Delivery Needs a Thermal Mass Flow Meter
Cleanroom vapor delivery is not compressed air. The vapor line may run at 121 °C and 2 bar with flow below 1 kg/h. A thermal mass flow meter measures heat transfer from a heated sensor to the moving vapor. That direct mass flow signal is stable even when vapor density changes.
Most engineers skip this part. Some teams try to reuse a liquid oval gear meter or a Coriolis meter with a viscosity reading in cP. That causes trouble on low pressure vapor because the mass flow is too small and liquid meters are not built for gas phase measurement. Because vapor density changes with pressure and temperature, a volume based flow meter can also drift. A thermal mass meter with a PT100 reference sensor handles these cases better. That is why Bronkhorst thermal mass flow meters appear in many cleanroom humidity and solvent delivery skids.
Bronkhorst Manuals and What They Actually Cover
A Bronkhorst manual is not only a wiring guide. It includes zero point check, purge sequence, valve settings, and alarm codes. For cleanroom vapor delivery, the manual also shows how to switch from nitrogen calibration to water vapor or IPA vapor. This conversion table helps if the meter was purchased second hand or moved to a new process.
We have seen this on customer sites many times. The original manual is lost or the PDF is buried in a validation folder. A semiconductor packaging line in Malaysia waited two weeks for a printed manual while a DN15 vapor meter sat offline. If you need a replacement meter and manual quickly, Silver Instruments sends a printed manual plus a HART register map with every shipment.
Sourcing a Bronkhorst Thermal Mass Flow Meter Without the Long Lead Time
Bronkhorst is reputable but not always fast for small projects. Skid builders in Vietnam and Thailand often ask us for a same size replacement when a cleanroom vapor line cannot stop for eight weeks. The process connection usually is 1/4 inch compression fitting, DN15 Tri-Clamp, or DN25 flange. The hard part is not the mechanical fit but the calibration gas and flow range.
Here is the thing. Send Silver Instruments your vapor type, pressure in bar, temperature in °C, pipe size DN, and flow range in kg/h. We return a quote with the model, wiring pinout, and expected lead time. This works for water vapor, IPA vapor, and solvent vapor lines from 0.5 kg/h to 100 kg/h.
Silver Instruments Thermal Mass Flow Meter Series
For cleanroom vapor delivery, Silver Instruments offers three common configurations. The SIL-TMF-C15 capillary series covers 0.05 kg/h to 10 kg/h with 1/4 inch or 3/
8 inch compression fittings. The SIL-TMF-DN15 and SIL-TMF-DN25 inline series covers 0.5 kg/h to 100 kg/h with Tri-Clamp or flange bodies. The SIL-TMF-PRO insertion series covers DN40 and larger headers, with a 316L probe and PT100 reference.
All units output 4-20 mA HART. Optional outputs include RS485 Modbus RTU, pulse, and two relay alarms. For cleanroom use, choose electropolished wetted parts and no paint external surfaces. If the line sits in ATEX Zone 1, specify that during the quote stage. Conductivity in µS/cm can be useful for cleanroom water quality checks, but it does not help size a vapor flow meter.
Common Sizing Mistakes in Cleanroom Vapor Delivery
A meter sized for nitrogen may read low on water vapor or IPA vapor. Thermal mass flow meter calibration is gas specific. If the original Bronkhorst meter was calibrated on nitrogen and the process vapor is different, the reading will have an offset. Many users fix this with a correction factor from the manual, but the uncertainty increases.
In practice, a paint manufacturer in Southeast Asia learned this when a thermal mass flow meter on solvent vapor read 0.8 kg/h but the actual consumption was 1.1 kg/h. So the replacement meter from Silver Instruments was calibrated on the actual solvent vapor. The control loop stabilized the same day.
What to Send for a Sourcing Quote
Do not send only a model number. Many nameplates are worn or the code does not show calibration gas. Send the process data instead. Vapor type, pressure in bar, temperature in °C, pipe size DN, flow range in kg/h, and connection type.
If the cleanroom line uses ultrapure water vapor after a WFI generator, mention the moisture level and whether the meter will be steam in place sterilized. That changes material choice and sensor sealing. Silver Automation Instruments can match the wetted material to 316L, Hastelloy, or electropolished 316L.
Can you supply a direct replacement for a Bronkhorst thermal mass flow meter? In many DN15 to DN50 cleanroom vapor lines, yes. The process connection and 4-20 mA HART output match. Check zero and span settings first because Bronkhorst and Silver Instruments may use different default ranges.
Do you provide cleanroom vapor delivery manuals? Yes. Each meter ships with a printed manual, wiring diagram, HART register map, and calibration certificate. A PDF is available before shipment if your validation team needs it early.
Which gases do you calibrate? Nitrogen, air, water vapor, IPA vapor, carbon dioxide, argon, and oxygen are standard. Specialty vapor calibration takes 3 to 5 extra days.
What is the typical lead time? Standard DN15 and DN25 thermal mass flow meters ship in 7 to 10 days. ATEX Zone 1 insertion versions ship in 12 to 15 days. Add 3 days if you need a HART modem test report.
How do I get an exact price for a cleanroom vapor delivery flow meter? Send gas type, pressure in bar, temperature in °C, pipe size DN, flow range in kg/h, and connection type to Silver Instruments. WhatsApp works fastest for urgent skid projects.
Contact Silver Instruments. Tel: +86-135-1213-1526. WhatsApp: 86-135-12131526. WeChat: +86 13512131526.
