『2 inch flow meter|magnetic flow meter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
What is the English abbreviation for cubic meter?
Cubic meters are abbreviated as m ³. Vocabulary analysis definition: cubic meter; 1. An abundant landslide fell into the reservoir and displaced fifty million cubic meters of water. Due to a massive mudslide sliding into the reservoir, 50 million cubic meters of water overflowed.
2. The exploration capacity will hit 1 trillion cubic meters.
3、The dam is noted for spillway with a rate of about 1370 cubic meters per secondand a diameter at the lip of 22 m. It is famous for its 22 meter diameter spillway that releases 1370 cubic meters of water per second.
4、The gauging station at the mouth of the canyon recorded peak flow of 883 cubic meters per second, four times higher than the previous record flood. The water level station at the mouth of the canyon recorded a peak flood flow of 883 cubic meters per second, five times the previous record.
5、The 40 liter container under pressure of 150 atmospheres contains 6 ubic metersof helium. A 40 liter container contains 6 cubic meters of helium gas at 150 atmospheres.
2. Urgent need for English vocabulary related to fitters.. Thank you
For the strong grinding of the abrasive material, the absence of grinding is not present, and the accessory accommodation is missing. Therefore, the accuracy is adjusted accordingly, and the accuracy actuator starts (machine) to drive sufficient adhesive agent adjacent to the edge. The adjacent adoption adopts the advanced, advanced, and desirable agile shaking, a large extent algorithm alignment positioning, alignment correction, all too free frequent allowance tolerance, and the margin alternate alternate alternately. Alternatively, aluminum
