Nozzle flowmeter model
Structure and form of standard nozzle flowmeter | Doppler flowmeter manufacturer | Is there any difference in the installation of nozzle flowmeter, and is there a groove like orifice flowmeter? | Product introduction of Guangdong Zhongguan Fluid Technology Co., Ltd. | What is the grade standard of flowmeter|
Effevtive Time:7/18/2026
Keywords:Structure and form of standard nozzle flowmeter | Doppler flowmeter manufacturer | Is there any difference in the installation of nozzle flowmeter, and is there a groove like orifice flowmeter? | Product introduction of Guangdong Zhongguan Fluid Technology Co., Ltd. | What is the grade standard of flowmeter|
Company:liquid flow sensor
『Nozzle flowmeter model』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. Is there a reverse angle when installing a nozzle flowmeter, just like an orifice flowmeter, which has a groove?
There is a reverse angle when installing a nozzle flowmeter. The groove of a 1/4 circular nozzle is not straight like an orifice plate, but a 1/4 arc. When installing the rental mold, the large mouth (arc) should face forward (the orifice plate should have the large mouth facing backward). When installing the nozzle and long nozzle, the arc faces forward, while the narrow and gentle nozzle faces backward.
2. Product Introduction of Guangdong Zhongguan Fluid Technology Co., Ltd.
Guangdong Zhongguan Fluid Technology Co., Ltd. is a global supplier specializing in industrial nozzles and flow meters. Its products include ultrasonic flow meters, multi-element flow meters, multi-element nozzles and other supporting equipment, which are widely used in semiconductor, photovoltaic, food, pharmaceutical, chemical and other fields.
. The ultrasonic flowmeter series is designed for accurate measurement of liquid flow in pipelines, with the characteristics of easy installation and stable performance. Pipeline type ultrasonic flowmeter: adopts double command (flexible connection) connection to ensure reliable connection and easy operation; The straight tube design effectively reduces pressure loss and is suitable for scenarios sensitive to fluid resistance. External card ultrasonic flowmeter: automatically engaged through circular magnetic steel, installation and measurement only take 2-3 minutes, equipped with OLED display screen, time resolution up to 50ps, can quickly obtain high-precision data, suitable for temporary or rapid deployment needs. In addition to ultrasonic flow meters, the com
pany also offers various types of flow meters to meet differentiated needs: dual indication rotor flow meters: synchronous display of flow rate and cumulative amount is achieved through dual pointer design, suitable for scenarios that require simultaneous monitoring of instantaneous flow rate and total amount. Gas rotor flowmeter: optimized for gas media, with high sensitivity and anti-interference ability, suitable for gas flow monitoring scenarios such as chemical and environmental protection. Flanged flowmeter: It can be quickly installed through flange connection and is suitable for large-diameter pipe blocking channels or industrial environments that require frequent disassembly and assembly. Alarm type flowmeter: Integrated with abnormal flow alarm function for land excavation, with preset threshold. When the flow exceeds the range, the alarm will be automatically triggered to ensure production safety. Acid and alkali resistant flowmeter: made of special materials and anti-corrosion coatings, suitable for flow measurement of highly corrosive media (such as acid and alkali solutions), extending the service life of the equipment. Multi nozzle selection: The companys nozzle products have high precision and corrosion resistance as their core advantages: quick detachable nozzles: achieve second level disassembly and assembly through quick connection structures, suitable for cleaning or spraying scenarios that require frequent nozzle replacement. Clip on nozzle: Adopting a clip on fixing method, it can be installed without the need for simple tools, suitable for space limited or temporary use scenarios. Integrated nozzle: The nozzle is designed to be integrated with the connector to reduce the risk of leakage and is suit
