Hoffer Flow Meter Catalog: Precision Cryogenic Liquid and Aerospace Fuel Turbine Instruments
Keywords:Hoffer Flow Meter Catalog: Precision Cryogenic Liquid and Aerospace Fuel Turbine Instruments
Company:liquid flow sensor
『Hoffer Flow Meter Catalog: Precision Cryogenic Liquid and Aerospace Fuel Turbine Instruments』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Hoffer Flow Meter Catalog: Precision Cryogenic Liquid and Aerospace Fuel Turbine Instruments Reference
Quick Answer: Hoffer turbine flow meters serve cryogenic liquids and aerospace fuel test stands because they handle low flow, wide temperature ranges, and pulse output. Silver Automation Instruments supplies equivalent precision turbine flow meters with 4-20 mA HART and ATEX options. Send your pressure in bar, temperature in Celsius, pipe size in DN, and flow range in kg/h or L/min to get a matched model.
What the Hoffer Catalog Covers for Cryogenic Liquid
The Hoffer flow meter catalog lists precision turbine meters for liquid nitrogen, liquid oxygen, LNG, and liquid hydrogen. Operating temperatures can drop to minus 253 Celsius. That is the boiling point of liquid hydrogen. Flow ranges often start from 0.1 L/min in small line sizes. This matters for test benches and pump skids.
Silver Instruments cross references many Hoffer catalog configurations. A typical cryogenic turbine meter body uses 316L stainless steel. Bearings use tungsten carbide or ceramic. The pickup coil can be magnetic or modulated carrier. Output options include raw pulse, amplified pulse, and 4-20 mA with HART. This setup is common in LNG bunkering skids in Malaysia and Indonesia.
Most engineers skip this part. The meter must be warmed and purged before liquid oxygen service. Any hydrocarbon residue creates a safety risk. For this reason the Silver Instruments cleaning procedure follows ASTM G93. The meter bag is sealed after final cleaning. We have seen this on customer sites many times on rocket fuel fill carts.
Aerospace Fuel and Turbine Flow Meter Accuracy
Aerospace fuel measurement covers Jet A-1, RP-1, and hydrazine. Calibration rigs need repeatability better than 0.05 percent. A turbine flow meter can reach that when fluid viscosity stays below 5 cP. Pulse output simplifies batch control. But you need straight upstream pipe. Hoffer catalogs usually recommend 20 diameters upstream and 5 diameters downstream. That detail reduces swirl and flow profile error.
Silver Instruments supplies inline turbine meters from DN4 up to DN200. A DN15 meter for RP-1 at 20 bar and minus 40 Celsius can cover 0.5 to 10 L/min. The same size works for a fuel additive injection test bench. We supplied a similar setup to a pump repair shop in Vietnam. The shop needed a low flow meter with PT100 temperature compensation. The final bill of materials included a pulse divider, a rate totalizer, and a 4-20 mA HART transmitter.
Model Selection for Cryogenic Liquid and Fuel Test Stands
Use the Hoffer flow meter catalog as a starting point. Then compare the Silver Instruments equivalent by these parameters: flow rate, viscosity, pressure, temperature, and output signal. For liquid nitrogen in a 1 inch line, a typical meter covers 10 to 150 L/min at 10 bar. For liquid hydrogen in a 1/2 inch line, the range may drop to 2 to 30 L/min because density is low. Bearings need special clearance.
A practical model mapping looks like this. For DN15 cryogenic liquid service choose Silver Instruments model SIL-TUR-DN15 with 316L body and ceramic bearings. For DN25 aerospace fuel calibration choose SIL-TUR-DN25 with PTFE seals and a dual pickup. For DN50 LNG bunkering choose SIL-TUR-DN50 with an explosion proof housing rated ATEX Zone 1. The transmitter can be remote or integral. Remote mounting is better when the process temperature is below minus 100 Celsius.
In practice you will also need a K-factor certificate. The K-factor is pulses per litre. Silver Instruments provides a 5 point calibration curve from a traceable master meter. This is the part that turns a good turbine meter into a usable fiscal meter. Request the calibration certificate before shipping. It costs extra but it is worth the time.
Installation, Purge, and Calibration on Site
Installation errors cause more return requests than sensor defects. A cryogenic turbine meter cannot be installed in a wet line. Moisture freezes inside the bearing area. That blocks the
rotor. Commissioning should follow a nitrogen purge, a slow cool down, then a flow test. Flow should start low and increase step by step. Sudden liquid gas expansion damages the rotor assembly.
We have seen this on customer sites many times. A cargo pump skid in Australia had a turbine meter with a damaged rotor because the operator opened the valve too fast. The flow surged past the maximum limit within two seconds. The bearings cracked. Since then the site added a soft start valve upstream.
For aerospace fuel test stands the biggest issue is air release. Jet fuel absorbs air. When pressure drops, bubbles form. That causes the turbine meter to over-read. The solution is a back pressure valve downstream. Keep system pressure at least 3 bar above the vapor pressure of the fuel. Use a flow conditioner if straight pipe is not possible.
Output Signal and Control System Integration
The turbine meter flow signal typically enters a PLC, a flow computer, or a rate totalizer. Pulse output is common. Some control rooms need 4-20 mA HART. Silver Instruments can supply a converter mounted on the meter or in a remote enclosure. For cryogenic service remote electronics are better. The cold temperature can damage an integral display.
Communication options include RS485 Modbus RTU. Some customers ask for two outputs. That means one pulse output for flow total and one analog output for flow rate. The dual pickup version is useful for aerospace fuel test stands. It reduces false pulse counts from vibration. The signal conditioner can also filter low amplitude noise.
Here is the thing. Check the meter cable shielding. Use twisted shielded pair cable. Ground only at the PLC end. That avoids ground loops. A 4-20 mA HART signal can run 300 metres without issue. Pulse output should stay below 50 metres unless a line driver is used.
How to Get a Quote Without Catalog Guesswork
Do not start with a general message. Send us the pressure in bar, temperature in Celsius, pipe size in DN, and flow range in kg/h or L/min. Also tell us the fluid name. Liquid oxygen is not the same as liquid nitrogen. Density and specific gravity affect the turbine meter range.
For a fast cross reference to the Hoffer flow meter catalog, send the model number or the existing part number. Silver Instruments can check the line size, end connections, flow range, and output type. We serve customers in Southeast Asia, Oceania, Latin America, Middle East, and Africa. Typical lead time for a standard DN15 to DN50 turbine meter is 3 to 5 weeks. Custom cryogenic cleaning adds 3 days.
Contact Silver Automation Instruments today. Tel: +86-25-68650347. Whatsapp: +86-25-52155837. WeChat: +86 15365082610. Tell us the exact application and we will return a model proposal with a quote.
Can a Hoffer turbine flow meter measure liquid hydrogen?
Yes. A special cryogenic turbine flow meter with ceramic bearings can measure liquid hydrogen. The meter must be cleaned for oxygen service and the flow range must match the low density of the fluid.
What output signal should I choose for aerospace fuel test stands?
Use a pulse output for batch control and add 4-20 mA HART for flow rate signal. A dual pickup version is better for high vibration stands.
Does Silver Instruments offer an equivalent to the Hoffer catalog model?
Yes. Provide the Hoffer model number or the flow rate and pipe size. Silver Instruments will cross reference the mechanical and electrical specifications.
What is the typical repeatability for cryogenic turbine flow meters?
A good turbine flow meter reaches plus or minus 0.05 percent repeatability. Accuracy depends on calibration and fluid viscosity. For aviation fuel calibration benches expect plus or minus 0.25 percent reading or better.
How do I get a price for a DN25 turbine flow meter?
Send your pressure in bar, temperature in Celsius, fluid name, and flow range in L/min. Use Whatsapp +86-25-52155837 or Tel +86-25-68650347.
