『Velocity area method flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
Do you know several methods for measuring flow in irrigation areas?
There are several methods for measuring flow in irrigation areas, including the water level gate opening characteristic curve method. Applicable scenarios include the construction of lead and rubber monitoring points near the dry rise of water gates, as well as scenarios where the channel water surface has a certain width and gate control, such as a channel water surface width of 50 meters and a 3-hole gate.. Principle: Calculate the flow rate based on the characteristic curve of the opening of the water level locust gate (distinguishing between submerged flow and free flow). Supporting equipment and data transmission: The radar water level gauge is used to read the water level before and after the gate, and the gate position gauge measures the gate height. The data is transmitted to the cloud through a telemetry terminal using GPRS. Customers can remotely issue control instructions to the local PLC through computer web software based on the existing water level and gate position, thereby controlling the gate opening or the start stop of the pump station water pump. Doppler ultrasonic flowmeter flow measurement method: Applicable scenarios: monitoring points in channels with flat water surfaces but inconsistent surface and bottom flow velocities, and deeper water. According to the width of the channel surface, choose to use single or double vertical monitoring methods. For example, if the channel water surface is 10 meters wide, the single vertical flow measurement method can be used. Principle: Doppler ultrasonic flowmeter flow velocity measurement is based on the Doppler effect. The probe emits a beam of ultrasonic waves obliquely upwa
_500x500.jpg)
