『Installation method of Doppler flowmeter』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
1. Xiangfeng Technology FV-LSX-1 Portable Doppler Ultrasonic Flow Meter
Xiangfeng Technology FV-LSX-1 Portable Doppler Ultrasonic Flow Meter is a device that uses the Doppler effect to measure fluid flow velocity and flow rate. It is suitable for open channels, rivers, pipelines and other scenarios, especially for measuring liquids with high impurity content. The following is an introduction to the working principle, product characteristics, installation method, and application field of the type: Working principle Doppler effect basis: Ultrasonic transmitter is a fixed sound source, and solid particles in the fluid act as "observers" to reflect sound waves. The frequency difference (Doppler shift) between the emitted and received sound waves is proportional to the fluid flow velocity, and the flow velocity can be calculated by measuring the frequency difference. The formula is: fd=(2f/c) × v × cos θ, where fd is the received frequency difference, f is the transmitted frequency, c is the ultrasonic velocity, and θ is the angle between the water flow and the incident wave. Flow calculation: Combining the water depth data measured by the built-in pressure type water level gauge, the liquid flow rate is calculated using the velocity area method (flow velocity x flow area). Multi sensor collaboration: pressure type water level gauge: measures the overall water depth and evaluates whether the equipment is blocked by silt (data is valid when the difference with the ultrasonic water level gauge is within a reasonable range). Ultrasonic water level gauge: accurately measure specific water depth. Water temperature sensor: compensates for the influence of water temperature on sound velocity and improves measurement accur
