Nano Flow Meter Precision Control In Analytical Chemistry
Effevtive Time:7/27/2026
Keywords:Nano Flow Meter Precision Control In Analytical Chemistry
『Nano Flow Meter Precision Control In Analytical Chemistry』Related information(v cone flow meter|rotary gas meter|gallon meter|gear meter|metal tube rotameter|glass tube rotameter|nutating disk meter|transit time ultrasonic flow meter|wedge flow meter|pd meters|hydraulic flow meter|ultrasonic water flow meter|water flow meter|air flow meter|magnetic water flow meter|oxygen flow meter|gas flow meter|argon flow meter|air velocity meter|gasoline flow meter|fuel flow meter|ultrasonic water meter|digital water meter|nitrogen flow meter|solid flow meter|Oxygen tank flow meter|digital water flow meter|diesel fuel flow meter|steam flow meter|02 flow meter|compressed air flow meter|oil flow meter|liquid flow meter)
将以下 HTML 代码复制到文本编辑器,保存为 `.html` 文件后用 Word 打开即可直接使用。 ```html
Nano Flow Meter Precision Control in Analytical Chemistry
Quick Answer: Nano flow meters bring direct mass flow control into analytical chemistry, powering HPLC gradients, micro-reactor dosing, and spectroscopic autosamplers. Silver Automation Instruments supplies Coriolis meters that measure as low as 0.005 mL/min with an accuracy of 0.1 percent of reading and thermal mass flow controllers for gases down to 0.01 mL/min. These instruments ignore temperature and pressure shifts common in busy labs, giving you repeatable peaks and lower solvent waste.
Why Direct Mass Flow Matters in Analytical Labs
Many chemists in Thailand and Peru still run syringe pumps or dual piston HPLC pumps without a mass flow check. But volumetric pumping drifts when room temperature changes by a few degrees. The mobile phase viscosity shifts, and your retention times wander. A Coriolis nano flow meter from Silver Instruments, such as the CMF-Micro series, reads mass flow in g/h. It does not care if your acetonitrile viscosity moves from 0.37 cP to 0.34 cP. You feed the exact mass required, so a 40:60 gradient stays stable across a 15-hour sequence. That is the real precision control analytical chemists need.
Coriolis vs Thermal Mass Flow for Nano Dosing
For liquid feeds under 500 mL/min, we recommend a Coriolis meter. It gives direct mass flow, density, and temperature with one sensor. For gas flows like GC carrier lines, sample conditioning, or calibration gas blending, a thermal mass flow controller is the better fit. Silver Instruments MFC-100 uses a laminar flow element and a PT100 sensor. Its measuring range starts at 0.01 mL/min for nitrogen and helium. Response time is under 0.8 seconds. A landfill gas analyzer lab in Saudi Arabia used our MFC-100 to stabilize sample flow into a TCD detector. So liquid or gas, you have a nano meter for your analytical system.
Key Specs for Nano Flow Meter Selection
When you specify a nano flow meter for an analytical instrument, several details matter more than brochure accuracy. Wetted materials must be compatible with your mobile phase. The CMF-Micro 1 from Silver Instruments has a DN1.6 Hastelloy C22 tube option for aggressive solvents like THF or ammonium formate buffers. Process connections are 1/16 inch Valco type, common in HPLC and ion chromatography systems. The flow range is 0.01 to 10 mL/min for water-like liquids. Accuracy is plus or minus 0.1 percent of rate with repeatability better than 0.05 percent. Communication outputs include 4-20 mA HART, pulse, and RS485 Modbus RTU. These match the data logging needs of modern CDS software. If you handle flammable vapors, ask for an ATEX Zone 2 certification. We have built such meters for bi
odiesel analysis in Brazil and reactor monitoring in South Africa.
Real-World Example: HPLC Gradient Mixing in a Vietnamese Lab
A contract testing lab in Ho Chi Minh City contacted us last November. They ran USP monograph methods on a Waters Alliance HPLC and noticed retention time shifts after lunch every day. The cause was a 3 degree Celsius room temperature rise that changed the methanol-water viscosity without altering the piston stroke. We installed two CMF-Micro 1 meters on the A and B solvent lines, right before the mixer. Post-installation, their RSD on retention time fell from 1.2 percent to 0.15 percent. Acetonitrile consumption dropped by 15 percent because the mass ratio was always correct. Here is the thing: these meters paid for themselves in six months just from solvent savings and re-run avoidance.
How to Request a Quote for Your Analytical Flow Application
Email your fluid list, required flow range in microliters or milliliters per minute, operating pressure (bar), temperature (degrees Celsius), and preferred output signal to our engineering team. We will propose a meter with the right wetted parts, connection size, and calibration range. Tell us the instrument brand and model if you need a direct retrofit. We have supplied Silver Instruments nano flow meters to pharmaceutical QC labs in Bangladesh, food testing centers in Chile, and university research groups in Kenya. Send your specs now and receive a quotation within one business day. Visit our contact page for the submission form or write to sales at flow-meter.com.au.
Frequently Asked Questions on Nano Flow Meter Precision
Q: What is the lowest measurable flow rate for liquid nano meters? A: The CMF-Micro 0.5 from Silver Instruments measures down to 0.005 mL/min for liquids with viscosity up to 10 cP. Turndown is 100 to 1.
Q: Can the Coriolis meter handle dirty samples with particulates? A: Our CMF-Micro uses a single straight tube design that is less prone to clogging. We recommend a 10 micron in-line filter upstream. This has worked well in catalyst screening labs in Argentina.
Q: Is it possible to control the meter from a PLC or DCS? A: Yes. All nano flow meters output 4-20 mA HART and RS485 Modbus. You can set the flow setpoint remotely from a LabVIEW or DeltaV system.
Q: Do you provide calibration certificates for GMP labs? A: We ship every nano flow meter with a 5-point calibration certificate traceable to ISO 17025. Additional IQ/OQ documentation is available for pharmaceutical audits.
Q: How long is the delivery time for a nano flow meter? A: Standard models ship in 2 to 3 weeks. Custom wetted materials or ATEX certifications may add 1 week. We have stock in Australia and regional hubs in the Middle East.
